Manish Prasad Mon, 02/24/2014 - 04:50
dial-peer cor custom
name 9044
name 9045
name 901
name 900
name 9001
name local
name internas
dial-peer cor list Cell
member 9044
dial-peer cor list LADA
member 901
dial-peer cor list LADA-cell
member 9045
dial-peer cor list EU-CANADA
member 9001
dial-peer cor list Internacional
member 900
dial-peer cor list Ventas
member 9044
member 9045
member 901
member local
dial-peer cor list Ingenieria
member 9044
member 9045
member 901
member 900
member 9001
member local
voice register pool  5
id mac 000E.08D0.4E75
number 1 dn 5
cor outgoing Cell default
dtmf-relay sip-notify
username 3252 password 3252
codec g711ulaw
dial-peer voice 3 pots
trunkgroup PSTN
corlist outgoing Cell
description ** Unrestricted **
preference 2
destination-pattern .T
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
no digit-strip
Check this thread its has example
https://supportforums.cisco.com/thread/294647
Carlo Poggiarelli Mon, 02/24/2014 - 05:20
  • Green, 3000 points or more
Hi.
Have you tried to put the cor list in incommng direction?
cor incoming (corlist)
Let me know.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
