Warning message
Mac address: 0000.0104.0000
Answered Question
Feb 24th, 2014
I have a customer with large ISE/dot1x deployment were we just started doing some pilot testing on a few sites.
What we see now is a MAC address showing up on ports connected to Cisco AP's.
This MAC has in the last 24h made over 1200 sucsessfull attempts to authenitcate on diffrent swicthches on the test sites.
(We have the MAC address in the Endpoint DB)
It is only on ports going toward an AP and only on Cisco swicthes, we have Avaya as well.
We have seen this MAC before but not in this quantity as of today
Anyone seen this one before?
On the switch we cant see the MAC adress in tha MAC address table but it show in show authentication session
xxxx-xxxxx-xxxxx-SW03#sh mac address-table int fa0/6
          Mac Address Table
Vlan    Mac Address       Type        Ports
1100    xxxx.6a98.207f    STATIC      Fa0/6
xxx-xxxxx-xxxxx-SW03#sh authentication sessions
Interface  MAC Address     Method   Domain   Status         Session ID
Fa0/6      0000.0104.0000  mab      DATA     Authz Failed   xxxxxxxxxxx499
Fa0/3      xxxx.xxxx.f1ba  dot1x    VOICE    Authz Success  xxxxxxxxxxCF2
Fa0/6      xxxx.xxxx.207f  mab      DATA     Authz Success  xxxxxxxxxxx858
Fa0/1      xxxx.xxxx.8b4a  dot1x    DATA     Authz Success  xxxxxxxxxx7E3
Cheers
Message was edited
Correct Answer by Saravanan Lakshmanan about 3 years 4 months ago
yes, this that's the referenced bug CSCud97325 and it is fixed on 7.5.102.0, 7.4.121.X esc and 7.3.x.x esc build. If you don't want to update to 7.5.102.0 then open TAC case to get one of these fixed build.
Correct Answer by jimbostan about 3 years 4 months ago
Hi all,
     Check out bug CSCud97325............................thx...........J
Overall Rating: 5 (2 ratings)
jimbostan Fri, 03/28/2014 - 05:06
Mikael,
       I've just noticed a similar issue where this MAC (0000.0104.0000) shows up as well.  Were you able to resolve the issue?.....thx.......J
Mikael Gustafsson Fri, 03/28/2014 - 05:27
No, we have put this on suppress in the log for now. Short of time just now.
If you find anything please let me know :-)
Cheers
Jeff Deibel Fri, 03/28/2014 - 11:09
We have experienced an issue with this MAC address as well.
It appeared for a brief time on multiple ports connected to Cisco AP's and actually triggered port security violations, causing the AP's to disassociate from the controller.
I have not yet found the cause of this issue.
3750X - 12.2(58) SE2
5508 WLC - 7.2.111.3
2600 Series AP's
Correct Answer
jimbostan Tue, 04/01/2014 - 07:34
Hi all,
Correct Answer
Saravanan Lakshmanan Tue, 04/01/2014 - 08:48
  • Cisco Employee,
Related Content
Trending Topics - Security & Network
