Jabber 9.6 and Collab Edge
Feb 25th, 2014
I saw in another post that the Jabber for Win 9.6 need to log in internally to retrieve the jabber-config.xml file (with changes enabling MRA) to be able to register to the Expressway Edge/VCS E running X8.1 using auto discovery (searching DNS SRV collab-edge). The Jabber 9.7 should change this behaviour.
Any ideas if can we adjust the bootstrap file  (AUTHENTICATOR attributes) or use Manual Config to point to the  Edge should allow the JfW to log directly to the Edge without to register internally first?
