Warning message
Prime LMS Login Fail
Answered Question
Feb 25th, 2014
We installed a fresh prime LMS 4.2 successfully, we were able to login to the GUI, later we restored a backup taken from ciscoworks lms 4.0.1 but we were unable to login using any of the new created admin password or the old one as well.
We reset the password using the resetpasswd.exe utility but still we are unable to login, it gives a wrong credetials error.
If any one can assist in this case, thanks
Correct Answer by AFROJ AHMAD about 3 years 5 months ago
Stop the LMS service then.
Go to the servers command prompt and go to the following directory:
C:/Program Files/CSCOpx/bin>
Here type the following command:
perl ResetLoginModule.pl
Example:- C:/Program Files/CSCOpx/bin>perl ResetLoginModule.pl
Thanks-
Afroz
[Do rate the useful post]
****Ratings Encourages Contributors ****
Overall Rating: 5 (1 ratings)
AFROJ AHMAD Tue, 02/25/2014 - 06:50
  • Cisco Employee,
Hi Anas,
Was this previously Integrated with ACS ?
Did you tried login with different Browser ?
Can you try to reser the Password once again following the below link:
http://www.cisco.com/c/en/us/td/docs/net_mgmt/ciscoworks_lan_management_solution/4-2/user/guide/admin/admin/appendixcli.html#wp1016039
Share the output of pdshow  and stdout.log (NMSROOT/CSCOpx/MDC/tomcat/logs)
Thanks-
Afroz
Vinod Arya Tue, 02/25/2014 - 06:50
  • Cisco Employee,
Please make sure of following :
-The old LMS was not configured for AAA auth.
- The username and password of old LMS 4.0.1 should work, try it.
In case it doesnt work, try following :
1. Stop the Daemon Manager by typing on DOS: net stop crmdmgtd.
2. Go to this location:
Windows: C:\Program Files\CSCOpx\lib\classpath\com\cisco\nm\cmf\servlet\cwpass
Solaris: /opt/CSCOpx/lib/classpath/com/cisco/nm/cmf/servlet/cwpass
3. Rename cwpass to cwpass.oldbackup.
4. Now go to:
Windows: C:\Program Files\CSCOpx\lib\classpath\com\cisco\nm\cmf\servlet\orig\cwpass.
Solaris: /opt/CSCOpx/lib/classpath/com/cisco/nm/cmf/servlet/orig/cwpass
5. Copy the \CSCOpx\lib\classpath\com\cisco\nm\cmf\servlet\orig\cwpass to
\CSCOpx\lib\classpath\com\cisco\nm\cmf\servlet\.  Be careful NOT to delete the \orig\cwpass or you will loose the ability to reset the admin password.
6. Restart the Daemon Manager: net start crmdmgtd.
-Thanks
Vinod
**Encourage Contributors. RATE them. **
Anas Hijjawi Tue, 02/25/2014 - 06:56
Yes it was integrated with ACS, so in this case what should we do, is it the same solution you provided
Correct Answer
AFROJ AHMAD Tue, 02/25/2014 - 06:58
  • Cisco Employee,
Thanks-
Afroz
AFROJ AHMAD Tue, 02/25/2014 - 07:00
  • Cisco Employee,
You might need to reset the password again with passwd command. aftre running the last post command.
Thanks-
Afroz
Anas Hijjawi Tue, 02/25/2014 - 07:02
Looks Greate, I will try this tomorrow and update you, many thanks
AFROJ AHMAD Fri, 02/28/2014 - 05:11
  • Cisco Employee,
I am glad that it helped you
Thanks-
Afroz
Related Content
