02-25-2014 07:23 AM
I am running a Cisco 3750 on
12.2(58)SE2 C3750-IPSERVICESK9-M
I have an eem script which tracks routing updates as below
event manager applet route-table-monitor
event routing network 0.0.0.0/0 ge 1
action 0.5 set msg "Route changed: Type: $_routing_type, Network: $_routing_network, Mask/Prefix: $_routing_mask, Protocol: $_routing_protocol, GW: $_routing_lastgateway, Intf: $_routing_lastinterface"
action 1.0 syslog msg "$msg"
action 2.0 cli command "enable"
action 3.0 info type routername
action 4.0 mail server "<mailserveraddress>" to "<emailladdress>roger.perkin@domain.com" from "Switch 1" subject "Routing Table Change" body "$msg $_cli_result"
action 8.0 set msg "Route changed: Type: "
This works perfectly but I want to deploy this onto another 3750 running
12.2(50)SE3 C3750-IPSERVICESK9-M
When I configure the applet, event routing is not available?
Switch-2(config-applet)#event ?
application Application specific event
cli CLI event
config Configuration policy event
counter Counter event
env Environmental event
gold GOLD event
interface Interface event
ioswdsysmon IOS WDSysMon event
none Manually run policy event
oir OIR event
rpc Remote Procedure Call event
snmp SNMP event
snmp-notification SNMP Notification Event
syslog Syslog event
tag event tag identifier
timer Timer event
I assume that this version of code does not support the event routing?
My question is where do you find out this information of what eem code is supported in what version of code?
Roger
Solved! Go to Solution.
02-25-2014 07:56 AM
No, you have EEM 2.4 in this version of IOS. Routing requires EEM 3.0. You can use my guide to figure out what version of EEM you have.
https://supportforums.cisco.com/docs/DOC-8799
EEM 2.4 and higher shows the event detectors available using the "show event manager detector" command. A summary of EDs per version can be found in my CiscoLive presentations BRKNMS-3021 and BRKNMS-2030 at http://ciscolive365.com .
02-25-2014 07:56 AM
02-25-2014 07:58 AM
Thanks Joseph, I assume you do have to upgrade the IOS to upgrade the EEM version ?
Roger
02-25-2014 07:59 AM
Yes. An upgrade will be required.
02-25-2014 07:57 AM
I have found the reason for this now - different EEM versions
This can be found with - sh event manager version
On the working switch it is running Version 3.2
On the non working switch it is running Version 2.4 and the routing event detector is not present
So I am going to have to update the switch.
switch2# sh event manager version
Embedded Event Manager Version 2.40
Component Versions:
eem: (v240_throttle)2.21.114
eem-gold: (v240_throttle)1.2.37
eem-call-home: (v240_throttle)2.0.1
Event Detectors:
Name Version Node Type
appl 01.00 node0/0 RP
syslog 01.00 node0/0 RP
cli 01.00 node0/0 RP
counter 01.00 node0/0 RP
gold 01.00 node0/0 RP
interface 01.00 node0/0 RP
ioswdsysmon 01.00 node0/0 RP
none 01.00 node0/0 RP
oir 01.00 node0/0 RP
energywise 01.00 node0/0 RP
snmp 01.00 node0/0 RP
snmp-notification 01.00 node0/0 RP
timer 01.00 node0/0 RP
test 01.00 node0/0 RP
config 01.00 node0/0 RP
env 01.00 node0/0 RP
rpc 01.00 node0/0 RP
