RV320 vs 1921/1941
Michiel Beenen
Level 3
Level 3
Hello all,
I was wondering, what is the biggest difference between the RV320 and 1921/1941 cisco series routers?
Is throughput higher on 1921 series or same as rv320? Im basically looking for best GUI/Best performance router for upto 100 clients.
I dont need VPN perse, i dont need VOIP or any other things it basically just needs to do DHCP, DNS and NAT plus gigabit ofc.
Im noticing with the RV320, performance goes down a lot when you enable QoS services.
Greetings!
ccreacoon
I compared these routers a while ago, the 1921 should have less throughput according to specs.
Have the 1921 on a 50/50Mbit line here so don't know the practical max throughput with firewall enabled etc.
Leo Laohoo
If you like GUI, then 1921/1941 isn't going to be your "cup of tea".  These routers are mostly CLI.  Sure there are limited GUI functionality but a lot of us prefer CLI because there are more functions/features available with CLI than GUI.
Good to know, thank you.
I hope they will release an even better version then the RV320 in the future, cause i love its interface
