Catalyst 6500 VSS member stuck in rommon after a reload
Feb 25th, 2014
                   Hello Forum Team!
   I have a VSS member Catalyst 6500 (Supervisor 720, s72033_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(33)SXJ, RELEASE SOFTWARE (fc3)) stuck in rommon mode. The Supervisor has the ios in the bootflash:, but when tried to boot from this image, the following error appears and then goes again into rommon mode:
%Software-forced reload
14:46:04 AST Tue Feb 25 2014: Breakpoint exception, CPU signal 23, PC = 0x42E24578
   Possible software fault. Upon reccurence, please collect
   crashinfo, "show tech" and contact Cisco Technical Support.
!−−− Output suppressed.
*** System received an unknown failure ***
signal= 0x0, code= 0x0, context= 0x44cc2d64
PC = 0x419dedc0, Cause = 0x1020, Status Reg = 0x34008102
rommon 4 >*** System received an unknown failure ***
rommon 4 >
Thanks in advanced for any suggestions!
Leo Laohoo Tue, 02/25/2014 - 12:37
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Try a different IOS level.   How about SXJ1.
fuhrersk8 Tue, 02/25/2014 - 12:48
Hello and thanks for your reply;
   Do you mean upgrading to a newer iOS? The problem is that the other VSS member is up and running and that would require an upgrade too (production downtime).
Is there any troubleshooting that can be done before trying to upgrade?
Thanks again for your support!
Reza Sharifi Tue, 02/25/2014 - 14:20
    2017 LAN
while in rommon,set the boot variable and than reload.  set bootflash
fuhrersk8 Wed, 02/26/2014 - 06:10
Hello Reza and thanks for your reply; Setting the bootflash to the current ios software in the rommon bootflash will have the same result as booting the supervisor from the bootflash?
fuhrersk8 Fri, 02/28/2014 - 08:12
Hello guys; just an update: i set the bootflash to the ios version, set config register to x2102 , reset the Sup720 but still boots into rommon. Also, I tried booting form a compact flash from the working switch but still the same result.  I will proceed to replace the Sup720 linecard.
Thanks for your support.
Leo Laohoo Tue, 02/25/2014 - 15:06
  • Hall of Fame,
    2017 LAN, Wireless
I doubt it.  Something is causing your switch to crash and it's showing it's software-fault.  So running the same version might not be helpful, hence I'm recommending upgrading to something else.
