Warning message
2960S-24TS-L unable to upgrade to IOS 15.2(1)E1
Answered Question
Feb 25th, 2014
I have 9 switches all together currently running on IOS 15.0(1)SE2 (which originaly came together with those switches). As per company requirement, we need to standardize and upgrade all switch in the data center to the latest IOS 15.2(1)E1. But only these 9 switches are having problem, the rest of 2960 TS-L is working fine after the upgrade.
After the switch reloaded, it will boot up the IOS but with error. It seems like the switch will only boot up the basic feature of the IOS. Running config is not loaded. None of the interfaces detected. Couldnt find any bug related in Bug toolkit or similar case in this forum. It has permanent license. I have attached some of the IOS upgrade logs. If anyone can help me here I'd greatly appreciate it. Thank you.
Correct Answer by nicola.pinton about 2 years 5 months ago
So the only solution is to open a TAC case and hope the replacement?
This is awesome with a Cisco product!!
Leo Laohoo Wed, 02/26/2014 - 00:24
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
If you want a stable IOS, try 15.0(2)SE4.
I wouldn't even recommend 15.2(1)E1 to anyone else.
Mohd Zul Akmar ... Wed, 02/26/2014 - 00:46
I doubt it will work. I have tried with universalk9 150(2)SE2, 150(2)SE5 and 15.2(1)E1 so far, but none is working. Only IOS 12.2 and existing 15.0(1)SE2 works. But I will give another try with 15.0(2)SE4 and share my findings later.
Please note that I have 17 2960TS-L, only 8 is successfully upgraded.
Leo Laohoo Wed, 02/26/2014 - 00:50
  • Hall of Fame,
    2017 LAN, Wireless
Console to the switch and reboot.
I want to see the entire bootup sequence.
Leo Laohoo Wed, 02/26/2014 - 01:23
  • Hall of Fame,
    2017 LAN, Wireless
Boot sequence is fine.  I don't see any problems.
Anuar Shahrin Wed, 02/26/2014 - 01:59
I think the problem is with the license. If the switch has a lanbase license, it should be able to boot normally.
*Mar  1 00:00:20.808: Read env variable - LICENSE_BOOT_LEVEL =
Mar 30 01:27:38.047: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c2960s_lanbase Next reboot level = lanbase and License = No valid license found
Mar 30 01:27:38.062: %LINK-4-NOMAC: A random default MAC address of 0000.0c8a.c280 has
  been chosen.  Ensure that this address is unique, or specify MAC
  addresses for commands (such as 'novell routing') that allow the
  use of this address as a default.
Mar 30 01:27:39.347: %SYS-5-RESTART: System restarted --
Mohd Zul Akmar ... Wed, 02/26/2014 - 19:03
Thanks Anuar. I just realize the different of boot sequence between IOS 15.0(2)SE4 and 15.0(1)SE2 (which is came originally with the switch). Besides no interface has been loaded, a %LINK-4-NOMAC message came out when boot up from 15.0(2)SE4. Any idea if this related to my problem?
15.0(2)SE4
Press RETURN to get started!
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 15.0(2)SE4, RELEASE SOFTWARE (fc1)
15.0(1)SE2
*Mar  1 00:00:20.494: Read env variable - LICENSE_BOOT_LEVEL =
*Mar  1 00:00:20.850: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c2960s_lanbase Next reboot level = lanbase and License = lanbase
*Mar  1 00:01:42.917: %STACKMGR-4-SWITCH_ADDED: Switch 2 has been ADDED to the stack
*Mar  1 00:01:44.223: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
*Mar  1 00:01:44.223: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
*Mar  1 00:01:45.481: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Mar  1 00:01:45.785: %DC-4-FILE_OPEN_WARNING: Not able to open flash:/dc_profile_dir/dc_default_profiles.txt
*Mar  1 00:01:45.785: %DC-6-DEFAULT_INIT_INFO: Default Profiles DB not loaded.
*Mar  1 00:01:51.248: %SYS-5-CONFIG_I: Configured from memory by console
*Mar  1 00:01:51.495: %STACKMGR-5-SWITCH_READY: Switch 2 is READY
*Mar  1 00:01:51.495: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 2 has changed to state DOWN
*Mar  1 00:01:51.495: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 2 has changed to state DOWN
*Mar  1 00:01:51.867: %STACKMGR-5-MASTER_READY: Master Switch 2 is READY
*Mar  1 00:01:51.872: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 15.0(1)SE2, RELEASE SOFTWARE (fc3)
nicola.pinton Tue, 03/03/2015 - 00:18
Hi all, i have the same problem with a pair of 2960s. Any solutions to this problems?
I see that more people get this error with 2960s but none give the solution!
Mohd Zul Akmar ... Tue, 03/03/2015 - 00:35
Hi Nicola, mine was counterfeited switches. TAC case took me about 4 months and 3 TAC engineers to find the root cause. It was escalated to Cisco Brand Protection team. They replaced mine straightaway.
Correct Answer
nicola.pinton Tue, 03/03/2015 - 00:41
Related Content
