02-26-2014 07:23 AM - edited 02-21-2020 07:31 PM
Hello, I am trying to figure out how to force all traffic from remote vpn users to go through the vpn tunnel for internet access and have run into a road block. Right now, I have split tunneling working for one profile and the other profile is to force all traffic through the VPN. I have the same-security features enabled and I think I am stuck on the NAT side of it. What source of NAT settings do I need to allow this hairpining? My ACL is to allow any source to any outbound FYI.
- Gabe
02-26-2014 09:34 PM
What version of code?
Using an example of 10.2.3.0 as your VPN subnet.
8.2 and below
nat (outside) 1 10.2.3.0 255.255.255.0
global (outside) 1 interface (or PAT IP)
8.3+
object network VPN-Pool
subnet 10.2.3.0 255.255.255.0
nat (outside,outside) dynamic interface
02-27-2014 10:15 AM
Hi Johnston, thanks for the help! It is for version 9.x and I have configured the NAT. I am going to give that a shot and try it. Thanks,
02-27-2014 10:18 AM
I just made the change and no luck. Any thoughts as to where I might look to test? I ran the packet tracer and set it it up with the following:
interface - outside
source ip - vpn pool ip address
dest ip - google.com
reverse path failure is the result...
02-27-2014 10:32 AM
Please post the output of the command:
Show run nat
02-27-2014 12:42 PM
Could it be DNS?
What troubleshooting have you done?
02-27-2014 12:48 PM
I am able to resolve DNS entries from the internal DNS servers. Thanks-
02-27-2014 12:46 PM
Here is the output.
object network SHR_VPN_CLIENTS
02-27-2014 12:51 PM
Have you changed the source interface to inside and tested?
02-27-2014 12:56 PM
I just tried that and cleared the xlates no luck. I'll see if i can paste the packet trace output.
02-27-2014 01:01 PM
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (rpf-violated) Reverse-path verify failed
Shouldn't these commands fix this?
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
I don't want to disable RPF on the outside interface if I don't have too.
- Gabe
