Warning message
Mesh APs and outdoor install
Feb 26th, 2014
Can I use 2602i as a RAP and 1532i as a MAP with 2504 WLC?
Also, when installing the 1532i, do I need to use lightning arrestor?
What else do I need to install the 1532i outdoor?
I was reading the 1530 AP outdoor installation guide, but the instruction is for 1532e, and I am really confuse about the installation.
The site is something similar to this:
http://sniqi.com/wp-content/uploads/2013/10/pool-modish-roof-top-blue-swimming-pool-with-unique-rattan-gazebo-and-chic-aluminum-column-rooftop-swimming-pools.jpg
or
https://www.google.com/search?q=hotel+swimming+pool&espv=210&es_sm=122&source=lnms&tbm=isch&sa=X&ei=MGUOU-ycCKfz0QG2joDIBg&ved=0CAcQ_AUoAQ&biw=2133&bih=1061&dpr=0.9#facrc=_&imgdii=_&imgrc=vw5vFm9CLAiSUM%253A%3BmtarRnzeO5N33M%3Bhttp%253A%252F%252Fworldalldetails.com%252Farticle_image%252Fimpressive_swimming_pool_851671.jpg%3Bhttp%253A%252F%252Fworldalldetails.com%252FPictureview%252F5400-Impressive_Swimming_Pool_Bali_Indonesia_Hotel_Begawan_Giri_pool_view.html%3B1335%3B889
Is my topology feasible?
What I'm thinkig is, the APs that is going to be in the building with no walls will be 1532i RAP and the AP that is going to be in the indoor office will be 2602i RAP.  I have not seen the site yet, so far this is just my guess.
The wireless will be used for POS as far as I know. No guest traffic.
Scott Fella Wed, 02/26/2014 - 14:45
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
I would put the two 1532's on the top of your picture on the corner and have them as a RAP.  You can use the 2602's, but they are inside and your signal can be the issue.  If the signal from the 2602 is unusable, then the 1532's will never join.  If the signal is poor, then your backhaul will be poor.
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
steelinquisitor Thu, 02/27/2014 - 05:56
Scott,
Is there by a chance a guide how to install the outdoor AP? Something that would tell me what materials would I need to install these outdoor APs. I will be installing 1530i, but since outdoor APs requires more accessories than indoor AP, I am not exactly sure what to do or buy for the BOM.
The reason I put the RAP indoor and indoor with no walls is that I am not sure if I can pull cables to the location you have mentioned.
Scott Fella Thu, 02/27/2014 - 06:00
  • Hall of Fame,
    2017 Wireless
Take a look at this guide... I would also make sure that if you are running cable from one of 1532's as a RAP, that you use shielded outdoor cable and lightning arrestors.  This goes for any outdoor AP or Bridge that we do.
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/1530/installation/guide/1530hig/1530_ch2.html
Scott
steelinquisitor Thu, 02/27/2014 - 07:25
Scott,
How do power on your mesh outdoor APs? Do you use a regular wall power outlet or do you run a new power source?
This is the table I was looking at the other day.
The one that confusing me is that the lightning arrestor. Does the 1530i need a lightning arrestor? The guide focuses on the AP with external antenna.
Materials Required to Mount Access Point to a Vertical Wall
In Kit
Ground lug and screws (provided with access point)
Yes
Wall Mount Bracket
Yes
Four M6 x 12-mm Hex-head Bolts
Yes
Two stainless steel band clamps (adjustable 2"-5", 51 mm - 127 mm)
Yes
Two stainless steel band clamps(adjustable 5"-8", 127 mm - 203 mm)
Yes
Crimping tool for ground lug, Panduit CT-720 with CD-720-1 die (http://www.panduit.com)
No
Four wall mounting screws
No
Four wall anchors (specified for all material)
No
Drill bit for wall anchors
No
Electric drill and standard screwdriver
No
#6 AWG ground wire
No
Shielded outdoor-rated Ethernet (CAT5e or better) cable
No
Grounding block
No
Grounding rod
No
10-mm box-end wrench or socket set
No
Scott Fella Thu, 02/27/2014 - 07:32
  • Hall of Fame,
    2017 Wireless
Typically you can tap into an existing power source if it is available or run new power. The main thing is to make sure it's on a circuit that is constantly in and not timed. Street lamps for example will shut down and power up at given times. You want a power source that is constant. It an outlet is not too far from the AP, you can use that, but make sure it's protected from tampering and or weather.
steelinquisitor Thu, 02/27/2014 - 09:10
Scott,
Constantly power is a must since it is for POS devices. I found this weatherproof electrical box cover http://tinyurl.com/l78jm6p
Also, is there a rule that needs to be followed about grounding the Cisco outdoor AP?
Scott Fella Thu, 02/27/2014 - 16:57
  • Hall of Fame,
    2017 Wireless
Some come with a ground screw in which you would need to ground that like any other.... certified building ground.  If you run power, many times the junction box can be used as a ground, but the electrician would know.
Scott
Related Content
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
