Warning message
WLC 5508 - LAP1242: Failed to handle capwap control message from controller
Feb 27th, 2014
Hello everyone,
after finally successfully upgrading my WLCs from 6.0.199.4 to 7.6.100.0 there is another problem showing up...
If I want to change any configuration regarding the APs on the WLCs (which doesn't work) I get the following error-messages from the APs:
*spamApTask7: Feb 27 14:34:00.558: 00:3a:9a:d6:5d:30 Test-AP-09-03: *Feb 27 13:34:00.169: %CAPWAP-3-ERRORLOG: Validate Msg: msg type 12 does not supported payload 215
*spamApTask7: Feb 27 14:34:00.558: 00:3a:9a:d6:5d:30 Test-AP-09-03: *Feb 27 13:34:00.169: %CAPWAP-3-ERRORLOG: Validate Msg: error in Unknown Payload(215) payload (received length = 9, payload type = 215)
*spamApTask7: Feb 27 14:34:00.558: 00:3a:9a:d6:5d:30 Test-AP-09-03: *Feb 27 13:34:00.170: %CAPWAP-3-ERRORLOG: Failed to validate vendor specific message element type 215 len 9.
*spamApTask7: Feb 27 14:34:00.558: 00:3a:9a:d6:5d:30 Test-AP-09-03: *Feb 27 13:34:00.170: %CAPWAP-3-ERRORLOG: Failed to decode Configuration update request.
*spamApTask7: Feb 27 14:34:00.558: 00:3a:9a:d6:5d:30 Test-AP-09-03: *Feb 27 13:34:00.170: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 7 state 11.
*spamApTask7: Feb 27 14:34:00.558: 00:3a:9a:d6:5d:30 Test-AP-09-03: *Feb 27 13:34:00.171: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
Find attached some informations regarding the AP and the 5508.
Any suggestions are, as always, highly appriciated.
Manuel
Overall Rating: 5 (1 ratings)
Scott Fella Thu, 02/27/2014 - 05:51
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
When changes are made to an access point that is joined and configuration changes does not take, most of the time it's due to the amount of flash available. Take a look at the flash and verify that you have enough available space and check to see if you have unnecessary files you can remove if there is lack of space. Error files can also tell you that there are issues with that AP.
Sandeep Choudhary Thu, 02/27/2014 - 06:29
  • Purple, 4500 points or more
    2017 Wireless
Do the factory reset to AP and then try again. As scott stated that this is the issue with Flash space and you also have experiences with one of your other posts that 1242 dont have much space.
Grüsse
msporleder Thu, 02/27/2014 - 23:47
Good morning,
if I need free space at the flash: How much is "enough" to handle config changes?
Here you can see the filesystem of one of my accesspoints (all are affected):
AP#dir all-filesystems
Directory of arch:/
    2  -rwx       91288  Feb 22 2014 18:16:42 +00:00  event.log
    8  drwx         448  Feb 22 2014 18:16:38 +00:00  c1240-k9w8-mx.124-25e.JAO3
    4  drwx           0   Nov 2 2011 23:32:18 +00:00  configs
    5  -rwx         397  Feb 22 2014 18:19:03 +00:00  env_vars
    6  -rwx        6168  Feb 27 2014 18:14:24 +00:00  private-multiple-fs
No space information available
Directory of flash:/
15740928 bytes total (10614784 bytes free)
Directory of zflash:/
Directory of archive:/
No files in directory
Directory of system:/
    2  dr-x           0                      memory
    1  -rw-       17631                      running-config
Directory of nvram:/
   30  -rw-           0                      startup-config
   31  ----           0                      private-config
    1  ----        4100                      lwapp_ap.cfg
    6  ----         528                      lwapp_ap_tlv.cfg
32768 bytes total (26572 bytes free)
Regards, Manuel
Leo Laohoo Thu, 02/27/2014 - 23:55
  • Hall of Fame,
    2017 LAN, Wireless
This is most definitely created in error.  So you can create this entire sub-directory using the command "dir /f /r flash:zflash".
Brian Green Mon, 09/15/2014 - 11:34
I had this same issue and managed to resolve the problem by going to the WLC, clicking security -> AAA-> AP Policies -> Add
then adding the MAC, selecting MIC and check the box that says "Accept Manufactured Installed Certificate (MIC)
then apply
panda2311 Wed, 01/04/2017 - 09:55
Solve my problem with this process.
Thanks for your help..
msporleder Mon, 03/24/2014 - 01:48
Hello once more,
Cisco TAC told me that there are some known problems with 7.6+ WLC versions and 1242 APs.
"I’ve checked my internal database and I found out that there are some known issues with 1240 Aps in particular which are unable to save some updates (I can see here ssh), from the controller."
I had to go back to 7.4.121.0, afterwards I was able to configure the APs again with all options. Unfortionally I ran into some performance-problems with some clients, so I went back to the latest version 7.6.110.0.
So right now I am not able to configure SSH on the APs, but since it is enabled, everything is "fine" so far for me.
Hopefully Cisco can build a new version where these problems are solved.
Manuel
W S H FERNANDO Tue, 11/03/2015 - 00:32
I had the same issue, the problem is with country. What I did was check the "sh inventory" and see what model
AIR-CAP3702I-A-K9 this model is "-A" go  to WLC -> Wireless -> Country and check whether Regularaty Domain is available (in here also -A should be availbe) if not check the county and enbale it.
http://www.cisco.com/c/en/us/products/collateral/wireless/access-points/...
Follow below procedure to enable Regulalatary Domain
Disable 80211a/n/ac network "WLC-> Wireless -> 80211a/n/ac -> Network"
Disable 80211b/g/n network "WLC -> Wireless -> 80211b/g/n -> Network"
Enable required country
Enable all above disabled network
hope this will help you all
Regds
// 32400){ alert("Valid range for Interval is 10 to 32400 seconds"); return false; } } return true; } function showCcxBeaconInterval(){ if (document.forms[0].beaconMode.checked == false){ document.getElementById("ccx_beacon_id").style.display ="none"; }else{ document.getElementById("ccx_beacon_id").style.display ="block"; } } // ]]>
Related Content
Trending Topics - Security & Network
