Warning message
Disk Raid replacement on CUCM 7.1.5 on HP Server
Answered Question
Feb 27th, 2014
cant find a clear doc on it ...
i need to replace one disk that's about to fail.
my plan of action is to shutdown the subscriber server and pull out the disk then turn it back on so i have clear failure. once up insert the new disk
any advise?
thanks
Correct Answer by Gordon Ross about 3 years 5 months ago
The DL380G5 is a Cisco 7845. There are some variations to do with memory and HD discs. This (large!) table explains it all. (Look at the bottom!)
http://www.cisco.com/c/en/us/products/collateral/unified-communications/7800-series-media-convergence-servers/prod_brochure0900aecd8062a4f9.html
GTG
Please rate all helpful posts.
Overall Rating: 3.7 (3 ratings)
Gordon Ross Fri, 02/28/2014 - 10:34
  • Blue, 1500 points or more
You don't say what model of server, but if it's the Cisco 7845 (the re-badged DL380) then you should be able to pull out the drive and replace it without shutting down CUCM.
GTG
Louis-Philippe ... Fri, 02/28/2014 - 10:50
Hi Gordon. Thanks for that . i m all confused with server re badged stuff.. The server is hp dl380g5 ... How do i know what equivalent is it in cisco ? Cheers
Sent from Cisco Technical Support Android App
yahsiel2004 Fri, 02/28/2014 - 10:56
  • Gold, 750 points or more
Log into the CLI and do a "show status"
Yosh
