Warning message
7961 phone stuck with the speaker light on
Feb 27th, 2014
help!  I have a 7961 that powers up (flashes all lights) then squences the headset,mute, and power then a green light stays on the power. I have tried holding down the "#" key for a few minutes but still nothing happens past the three lights squencing. I connected the phone directly to my laptop running wireshark and there is no activity on the wire. I also tried my phone console cable and I am getting nothing.
Overall Rating: 5 (1 ratings)
Glenn Matthys Thu, 02/27/2014 - 23:34
Make sure you have the firmware for your phone ready with a correctly configured TFTP and DHCP server. Then:
* When the phone boots, before the speaker light goes on, hold the # key, keep holding until you see the line lights sequence (this takes a while before it happens)
* Once the lights have sequenced, key in the following:
1 2 3 4 5 6 7 8 9 * 0 #
This will factory reset the unit and the first thing it's going to try is download new firmware. You can monitor its progress using wireshark. It could be possible you don't see anything on the screen. Use the same version of firmware the unit was already running on.
jfaaborg Fri, 02/28/2014 - 09:22
It never gets to the point where the lines blink in squence to do a factory default. Also ran a wire shark and there is nothing on the port.
jfaaborg Tue, 09/02/2014 - 16:58
Nothing yet, I think they are just bricked.
maestro72x Tue, 09/02/2014 - 17:12
I had one today that was fine.. unpluged it and replaced it with another phone.. its green light turned on.. so i was like DAMN so i put the other phone back and then its green light turned on.. thats 3 phones now...
jfaaborg Thu, 09/04/2014 - 07:39
I had that day before... sucks to see a phone/s do that
jfaaborg Fri, 02/28/2014 - 09:26
Tried that. the phone will not go past the point of the speaker light. I've held down the # for minutes when powering on and it still just sits at the point where the speaker light is just on.
Dragan Ilic Mon, 03/03/2014 - 00:03
  • Silver, 250 points or more
Have you tried the sequence with started tftp32 software as I said in blog, besides everything? just to see if phone tries to load firmware or anything?
From tftpd32 log panel you can see if it's talking anything...
HTH,
Dragan
jfaaborg Mon, 03/03/2014 - 07:53
Ya, I tried it and never saw anything in the TFTP or DHCP log.
Dragan Ilic Mon, 03/03/2014 - 08:01
Well,
I can't be 100% sure but I think you should replace that phone
HTH,
Dragan
jfaaborg Mon, 03/03/2014 - 08:15
Looks like it is dead, but I'm hoping to find a fix. It is only a small amount of my 40,000 phones but I would like to try. Someone from Cisco hopefully has the answer!
dan.letkeman Tue, 05/06/2014 - 19:46
Did you find an answer for this?  I had the same problem with a 7965g today.  It happened after it was powered off and back on.  It never booted back up.
dan.letkeman Thu, 11/06/2014 - 08:12
Yes, I did find that field notice as well, and they will NOT honor warranty on this if you don't have a support contract.
Dan.
