Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1914924members
1215632discussions
Community Activity
请教3850交換机接口怎样引用PBR(策略路由)?
引用命令不知道是那里問題?g_core(config)#ip access-list extended hkbng_core(config-ext-nacl)#10 permit ip 10.105.20.13 0.0.0.0% Incomplete command.g_core(config-ext-nacl)#10 permit ip 10.105.20.13 0.0.0.0 anyg_core(config-ext-nacl)#exitg_core(config)#route-map hk...
D_W by Level 1
  • 39 Views
  • 3 replies
VCR 2220报错
VCR 2220报 RRQ timed out这个是什么意思,影响正常运行吗
lizi by Level 1
  • 48 Views
  • 1 replies
VRF without RD
Hi,Is it possible to configure an MPLS VRF without the use of RDs?  I have tried to get this to work in a lab but have been unsuccessful (I have always had to use RD to get it to work)If I were to set up a MPLS VPN between a Nexus switch which has VR...
CiscoNutt by Level 1
  • 3324 Views
  • 14 replies
Routing path
Hello,I have topology like this picture where we have 2 WAN connection to bridge LAN1 and LAN2. We use OSFP for the routing and we have NPM (from solarwinds) to monitor WAN connection from LAN1.In the NPM i create 2 node with ip 10.100.1.2 and 10.101...
hs08 by Spotlight
  • 75 Views
  • 1 replies
WinLogon Rerun disable other Credential Providers task
Hi There, It seems the Duo WinLogon installer disables other Credential Providers during installation. We're encountering problems when other credential component apps are patched they take precedence over Duo. Is there a task we can perform to resto...
SMulpuru by Level 1
  • 64 Views
  • 1 replies
Intégration de Cisco DUO avec Safeguard
 Bonjour à tous, Je suis sur un projet d'intégration de Cisco DUO pour une banque libanaise, j'ai déjà réussi à configurer le MFA pour fortigate SSL VPN, maintenant j'ai un problème pour configurer le MFA pour une solution PAM qui est "Safeguard for ...
msalhi by Level 1
  • 68 Views
  • 2 replies
Resolved! Default Static Route Help
Hello, I was trying to construct a simple network and got it up the specifications, however when the last step was to configure ipv4 static routes I couldn't quite get it to connect and ping end to end. I tried multiple things but nothing seemed to w...
Resolved! 4510+R ssh error after upgrade xe 3.11.07 to xe 3.11.09
Hi,after a upgrade from xe 3.11.07 to 3.11.09 we cannot open a ssh session to our 4510+R Switch. Before the upgrade everything works fine. The error message in the log  is:%SSH-3-BAD_PACK_LEN: Bad packet lenghthWe zeroised the  rsa key and generate i...
5/6GHz. One SSID to rule them all, or separate?
So, this is more a question of what people are using or seeing. We will be replacing all our facilities this year and I plan to go Wi-Fi6E. I have tested having the SSID with mixed, but I have also heard separate doe to if a client shifts frequencies...
PCCE 12k - Agent Explorer
Hi folks,We have a PCCE v12.6(1), 12,000 seats.when I click on "Agent Explorer" in Configuration Manager tool, an error message appears "The peripheral data required for the proper operation of this explorer is not present in the system or not access...
atoxet by Level 1
  • 161 Views
  • 4 replies
2024年4月思科技术开放日-专家讲堂(Ask the Experts)系列讲座
尊敬的思科客户/合作伙伴,感谢您一直以来对我们的支持,作为思科最重要的客户/合作伙伴,我们非常荣幸地邀请您参与“思科技术开放日 – 专家讲堂(Ask the Experts - ATXs)”专场培训讲座。在 2024年4月为期6场的培训讲座中,思科技术专家为您安排了丰富的内容。您将与思科的技术专家进行互动,学习如何使用思科产品来执行您的日常工作。此外,我们的专家将带您进行手把手的思科产品的演示及操作练习,这将为您提供关于思科产品如何简化您业务的全新视角。思科诚挚期盼您的参与,助您领航未来!培训安...
