02-27-2014 06:47 PM - edited 03-07-2019 06:27 PM
Hi Al,
I am having an issue with a Cisco 3850 Catalyst switch, issue as below:
- Current config register is 0x142 and have configured the config register to 0x102 but even after reload the new config register does not come in place.
- Have reloaded the switch 2x but with no luck. Changed the config register on the primary and secondary switch yet no luck. It is running SSO.
Show version:
sh ver
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.03.02SE RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Thu 20-Feb-14 21:17 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2014 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: CAT3K_CAA Boot Loader (CAT3K_CAA-HBOOT-M) Version 1.2, RELEASE SOFTWARE (P)
XXXX uptime is 1 day, 13 hours, 53 minutes
Uptime for this control processor is 1 day, 13 hours, 56 minutes
System returned to ROM by reload at 23:44:31 ADST Wed Feb 26 2014
System restarted at 23:50:23 ADST Wed Feb 26 2014
System image file is "flash:packages.conf"
Last reload reason: Reload command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
License Level: Lanbase
License Type: Permanent
Next reload license Level: Lanbase
9 Virtual Ethernet interfaces
56 Gigabit Ethernet interfaces
8 Ten Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
250456K bytes of Crash Files at crashinfo:.
250456K bytes of Crash Files at crashinfo-2:.
1609272K bytes of Flash at flash:.
1609272K bytes of Flash at flash-2:.
0K bytes of Dummy USB Flash at usbflash0:.
0K bytes of Dummy USB Flash at usbflash0-2:.
0K bytes of at webui:.
Base Ethernet MAC Address :
Motherboard Assembly Number :
Motherboard Serial Number :
Model Revision Number :
Motherboard Revision Number :
Model Number :
System Serial Number :
Switch Ports Model SW Version SW Image Mode
* 1 32 WS-C3850-24T 03.03.02SE cat3k_caa-universalk9 INSTALL
2 32 WS-C3850-24T 03.03.02SE cat3k_caa-universalk9 INSTALL
Switch 02
Switch uptime : 1 day, 13 hours, 56 minutes
Model Number : WS-C3850-24T
Configuration register is 0x142 (will be 0x102 at next reload)
Solved! Go to Solution.
03-12-2014 05:26 AM
09-19-2014 02:43 PM
Thank you! I've been banging my head on the wall for the last 45 minutes trying to figure this one out (; "no system ignore startupconfig switch all" and "switch all config-register 0x102" is what fixed it for me.
Cheers!
02-28-2014 07:08 AM
The output indicates it will change on the next reload (at least switch 02).
Give it a try.
03-07-2014 04:09 PM
I have a 3850 switch with an identical issue. I have been unable to get the device to boot using the existing config .
I have the following output in 'sh ver'
BUT the device does not reload with 0x102, at the next reload, but continues to exhibit identical behaviour after repeated reboots.
Kind regards
03-12-2014 05:26 AM
09-19-2014 02:43 PM
Cheers!
02-03-2016 08:46 AM
please use commands:
conf terminal
conf termin
exit
write mem
reload
Kind regards,
MG
09-26-2016 10:39 AM
Hi, Michal-
Thanks for your post - it's exactly what I needed to resolve this issue on a 3650.
-SLP
11-27-2016 06:26 PM
Thanks for your post. Also, precisely what I needed to resolve this issue on a 3650.
You're the best!!!
peter.carr@Boston10G.com
04-22-2017 04:11 AM
Hi Michal,
Above commands resolved this issue after spending 5 man-hours trying to resolve it!
THANK YOU VERY MUCH.
A.K.M
10-01-2018 03:04 AM
Hi I am having 3900 series router and above command is not working for me. could anybody please help me out?
10-01-2018 03:05 AM - edited 10-01-2018 03:09 AM
Hi I am having 3900 series router and above command is not working for me. My config register value is not changing even after reloading, could anybody please help me out?
05-16-2019 04:10 AM
thank you !
07-23-2019 08:32 AM
had the same problem on a brand new C9300-48UXM running 16.9.3. after adding the "no system ignore startupconfig switch all " and "config-reg 0x102" it corrected the problem. Thanks all
11-04-2019 11:32 PM
thanks
03-20-2023 04:37 AM
You are the best Michal, your 2-line solution has fixed my issue with C3650. you know i've configured my 3650 switch almost 20 times already; but it keeps lossing its configuration everytime i reload it. ooooh GOD bless Mr. Michal. lol...
