CUCM Video Call Over SIP Trunk
Answered Question
Feb 28th, 2014
Hi All,
Current Call flow.
EP --> CUCM ---> Avaya SM ---> VCS -- > EP.  Calls are always maturing as Audio Call. While checking the CUCM logs CUCM remove the Video capability in their SDP message.
When we are sending the call via direct trunk between CUCM & VCS video calls are woking fine.
Correct Answer by Suresh Subramanian about 3 years 5 months ago
Hello Sriram,
it seems the RSVP policy is disallowing the video call.
06647405.003 |12:12:13.844 |AppInfo  |SIPCdpc(18750684) - outCall_waitRSVPRes_PolicyAndCACRegisterRes: RSVP disallowing video call.
06647405.004 |12:12:13.844 |AppInfo  |Locations_getLocPKIDAndName -- loc= 0; pkid= 29c5c1c4-8871-4d1e-8394-0b9181e8c54d; Name = Hub_None
06647405.005 |12:12:13.844 |AppInfo  |Locations_getLocPKIDAndName -- loc= 15; pkid= a667d613-34fa-55f2-637f-abfdc54ab71a; Name = LOC-TBM-SIP-AVAYA AURA
>> so there is no video in the sdp.
06647405.009 |12:12:13.844 |AppInfo  |SIPCdpc(18750684) - convertMediaSDPMsgToSDP:
SDP:: isPresent=1, role=1
  numAudiomLines=1 numVideomLines=0
>> Please crosscheck the location settings & rsvp policy.
//Suresh
Please rate all the useful posts.
Overall Rating: 5 (1 ratings)
Manish Prasad Fri, 02/28/2014 - 02:34
Few things you can check.
If you have enabled early offer on both the trunks( to Avaya SM and to VCS) , compare the SIP messages. See the initial INVITE sent by CUCM does they carry video in SDP media ?
If yes then check the return SDP reply from Avaya SM and VCS , do they remove video from media in response ?
That may help which side is not allowing media.
Manish
gpsriramdc Wed, 03/05/2014 - 12:45
Hi Manish,
I have enabled the EO for the SIP trunk. SDP message from the CUCM to SIP trunk itself not having the Video capability.
Has anything we have to check in the Trunk or Region configuration ?
Nishant Savalia Fri, 02/28/2014 - 02:53
  • Silver, 250 points or more
Hi ,
Can you please share your detail trace from CUCM?
Is Avaya SM and VCS under your control? If yes then do send trace from respective.
Also mention calling number and called number?
Nishant Savalia
Suresh Subramanian Fri, 03/07/2014 - 05:09
  • Gold, 750 points or more
  • Community Spotlight Award,
    Mobile User, October 2015
Hello Sriram,
what is the calling number, called number & time of call?
how do you enable EO on the SIP trunk? by checking MTP? or on SIP profile?
Have you checked "Early Offer support for voice and video calls (insert MTP if needed)" in the SIP profile applied to that SIP Trunk?
//Suresh
//Suresh
Correct Answer
Suresh Subramanian Sat, 03/08/2014 - 06:15
Hello Sriram,
//Suresh
gpsriramdc Sat, 03/08/2014 - 08:22
Hi Suresh !
Thanks for your analysis. In Trunk Location is configured where no bandwidth allocated for the video .
Now the calls are working fine.
