Warning message
Which Version of ASA OS to Use?
Feb 28th, 2014
I've got an ASA 5505 currently running 8.4. I'm working on enabling dual stack with my ISP which is Comcast. So I need to upgrade to a newer version with more complete IPv6 support. I'm thinking about going directly to the latest version in the 9.1(x) series, skipping all in between. Is there any reason I shouldn't do this?
Thanks much!
Marius Gunnerud Sat, 03/01/2014 - 02:50
  • Red, 2250 points or more
  • Cisco Designated VIP,
    2017 Firewalling
There is no reason you should not go directly to 9.1(x).  I would suggest upgrading to the latest maintenance release as this version will have the most up to date caveat fixes.
Please remember to rate and select a correct answer
