Warning message
CUCM 9 user Page issue
Answered Question
Mar 1st, 2014
Hello ,
i am have cucm9 . i can not login user account when user is having Active Directory PAssword '''Error : username or password is incorrect ''
while i can login successfuly if i change the end user password on CUCM.
simply not working with Active Directory Passwords
please Advise .
Correct Answer by Aman Soi about 3 years 5 months ago
Hi Aslam,
To add more, prior to CUCM 9,
a. User cannot be added to CUCM, if LDAP was enabled.
b. ENd user need to be defined on LDAP and then, do the synchronisation.
But with CUCM 9
a. Administrator can have both Local and LDAP synced users.
b. we can modify local users and  roles assigned to LDAP users.
c. further, administrator can also convert LDAP user to local user.
d. Under the End Users page , u can differentiate Active Local users and Active LDAP synchronised users.
regds,
aman
Correct Answer by Chris Deren about 3 years 5 months ago
If the user is ldap integrated and you have ldap authentication configured you would not be able to change the password in CUCM, can you make sure ldap authentication is turned on?
Chris
Overall Rating: 5 (2 ratings)
Correct Answer
Chris Deren Sat, 03/01/2014 - 12:33
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Chris
aslam.bajwa Sat, 03/01/2014 - 12:41
thanks for reply  Chris ,
i will check and update you .
Correct Answer
Aman Soi Sun, 03/02/2014 - 00:11
  • Purple, 4500 points or more
    2017 IP Telephony
Hi Aslam,
But with CUCM 9
regds,
aman
