CallPickup by lifting handset - possible?
Mar 3rd, 2014
Hello together,
a user is in a PickUp Group and wants to PickUp calls just by lifting the handset, so he dosn't need to press "More"->"Pickup".
Is this possible?
We are running CCM 8.6.2 and use IP Phones 7962.
Thanks in advance
Timo
Overall Rating: 5 (2 ratings)
Chris Deren Mon, 03/03/2014 - 06:55
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Not really, you can enable auto call pickup via service parameter, but that only simplified pickup between groups, you will always need to press the pickup softkey.
HTH,
Chris
yahsiel2004 Mon, 03/03/2014 - 06:58
  • Gold, 750 points or more
Good info Chris (+5)
Yosh
TimoReyels Mon, 03/03/2014 - 22:30
Hello and thanks you Chris!
I've now set the service auto call pickup parameter to true, this works good enough.
Stupid users with their stupid requests
Timo
yahsiel2004 Mon, 03/03/2014 - 06:56
Timo,
I don't believe you can. You could assign the "Call Pickup" key to one of the phones line buttons. Would make it easier then scrolling through a softkey.
Yosh
John Huthmaker Mon, 03/03/2014 - 18:57
In my CCIE class I was told you can create a translation pattern with a blank pattern, and then translate it to any number.  Make sure to set Urgent Priority.  You could try this.  Make sure you put it in a special partition with a search space only used by this phone.  Otherwise ever person in the company would dial instantly dial your call pickup group the second they lift up their handset.
Chris Deren Mon, 03/03/2014 - 19:03
  • Hall of Fame,
That has nothing to do with call pickup feature, that is for PLAR and would force the phone to to route to the TP on every off hook which it typically desired only for certain phones.
Chris
John Huthmaker Mon, 03/03/2014 - 21:56
I've never done a call pickup group, and I'm travelling so I dont have access to my CallManager.  But correct me if I'm wrong.  isnt a callpickup group just an extension your phone dials when you press GPickup?  If it is, wouldnt you be able to create a translation pattern that dials it?
As I've said, I've never create a call pickup group before.  So I'm not 100% certain how they work.
yahsiel2004 Tue, 03/04/2014 - 05:01
John,
No you have to hit the "Call PickUp" key. Some PickUp options allow you to dial another Groups PickUp number but you still have to hit the GPickup or OtherPickup key.
Yosh
