trouble on getting an ip address for voice vlan in certain switches
farhanshariam
hi,
i had setup a new switch on a new building on my workplace and it seems that the switch is having problem releasing the ip add for the ip phone but have no problem at all with other devices.
the switch configuration is not the main problem i guess because it is pretty much the same with the other switches. can anyone having this kind of problem because the other switches did not giving me this kind of issue.
here is the mac-add table for the access switch
944    0015.6552.d914    STATIC      Gi1/0/12
here is the result when i try to filter it on an arp table.
9-5-cor1.net>sh arp | i 0015.6552.d914
9-5-cor1.net>
nothing on the arp table
i would be very happy to get an advice or solution from anyone. thanks
10 Replies 10
Dragan Ilic
Level 4
Level 4
Could you post part of config related to voice?
HTH,
Dragan
HTH,
Dragan
on core switch 1
interface Vlan944
ip address 192.168.1.252 255.255.252.0
ip helper-address 192.168.16.13
no ip redirects
standby 1 ip 192.168.1.254
standby 1 timers 5 15
standby 1 priority 110
standby 1 preempt
end
on core switch 2
interface Vlan944
ip address
192.168.1.253 255.255.252.0
no ip redirects
standby 1 priority 115
standby 1 preempt
end
on trunk port on core switch
interface GigabitEthernet2/24
switchport
switchport trunk native vlan 999
switchport trunk allowed vlan 900-999
switchport mode trunk
switchport nonegotiate
end
on the access port on access switch
interface GigabitEthernet1/0/10
switchport access vlan 910
switchport mode access
switchport voice vlan 944
switchport port-security maximum 2
switchport port-security maximum 2 vlan access
switchport port-security aging time 2
switchport port-security violation restrict
switchport port-security aging type inactivity
srr-queue bandwidth share 1 30 35 5
priority-queue out
mls qos trust cos
auto qos trust
spanning-tree portfast
spanning-tree bpduguard enable
end
on trunk port on access switch
interface GigabitEthernet1/0/50
priority-queue out
mls qos trust cos
auto qos trust
spanning-tree portfast disable
ip dhcp snooping trust
end
hope this helps.
Jeff Van Houten
Level 5
Level 5
Does the access switch have an svi in the 944 vlan? If not, the MAC address will never show in the arp table because ARPs are used to locate mac addresses in the same ip subnet as the interface that is sourcing the communication. No int vlan 944, no arp. The fact that the switch sees the entry in the mac addr table means the switch is likely doing its job. If you can't get dhcp to assign an address to a phone, I would suggest you check
The port configuration
The trunk configuration from this switch to the upstream
Where does routing occur for this subnet
Where is the dhcp server in all this? Same subnet or different? If different, do you have ip dhcp helper at the routing interface?
i have posted my configurations . hope those will answer your questions
Do you see any logs related to your port-security config? These lines:
I would preconfigure this in some way:
option 1:
option 2:
switchport port-security maximum 1 vlan access
switchport port-security maximum 1 vlan voice
It seems like your config is giving everything to access vlan (PC) and nothing left for phones...I can't confirm this but you can test with changing these parameters...
HTH,
Dragan
HTH,
Dragan
Guru Mysoruu
the below command should resolve all your problems.
Switch(config-if)#switchport voice vlan
Both ipphone and switch,starts communicating with the help of cdp..they both exchange information,once switch identifies end device has a phone,it will divert to voice vlan.so once it  get divert to voice vlan,everything will work fine.
Guru
I think he has that on access switch:
"switchport voice vlan 944"
HTH,
Dragan
HTH,
Dragan
Hi Muhammad,
.Try to do changes on port-secuirty config as belwo  ,sicne your config says allowed mac address
You are limiting the number of mac-addresses learned on a switch port for only data vlan. The thing to remember is that the maximum number of mac addresses learned on a port must be additive  number of mac addresses you have defined for the data and voice vlans. So if you would only want 2 MAC addresses learned on the data vlan and 1 on the voice vlan then the max number of maximum addresses you have for the port would be 3. Also note that the option for the max number of mac addresses learned for a voice vlan or data vlan within the port-security command will not show up until you tell the switchport about these vlans
Switch(config)# interface fastethernet0/1
Switch(config-if)# switchport mode access
Switch(config-if)# switchport access vlan 910
Switch(config-if)# switchport voice vlan 944
Switch(config-if)# switchport port-security
Switch(config-if)# switchport port-security maximum 3
Switch(config-if)# switchport port-security violation restrict
Switch(config-if)# switchport port-security mac-address sticky
Switch(config-if)# switchport port-security maximum 2 vlan access
Switch(config-if)# switchport port-security maximum 1 vlan voice
Also,Can you try removing the comamnd switchport nonegotiate on both the trunk ports from Core -> Access and Access -> Core. I mean to say this will not solve teh problem but yeah...woth this commamnd you are tirning off the DTP. If you obsrever an ything strange then add it backup. But idelaly it deosn't matter truningo ff DTP between two trunk ports. IT's ideal to do when switch is connected to a high latency specific serevsr or application serevrs.
farhanshariam
hi guys,
i did find something interesting in the access switch, when when i debug dhcp i got this:
DHCPD: No option 125
note: i did use an external dhcp server
carlos59
I think .. as i lerned in CCNA when you assign a port to voice VLAN you can only assign only one more data-VLAN and nothing more to the port.. and you can only configure that port mode access not as trunk so it should looks as follow :
S3(config)# vlan 20
S3(config-vlan)# name student
S3(config-vlan)# vlan 150
S3(config-vlan)# name VOICE
S3(config-vlan)# exit
S3(config)# interface fa0/18
S3(config-if)# switchport mode access
S3(config-if)# switchport access vlan 20
S3(config-if)# mls qos trust cos
S3(config-if)# switchport voice vlan 150
S3(config-if)# end S3#
and another question why do you want to set all these security configs when the port only can be assign to 2VLANs ?
i am still learnig my CCNA part 2
i hope i could help
