Cisco 3850 TACACS Issues
Mar 3rd, 2014
Guys
I have a Cisco 3850 running the latest code 3.3.2
GUI access (using Chrome) was working fine until we implemented TACACS.
Now we find we can access the GUI but not all screens work.
For instance - the WLANs are listed but you can't drill down into them for the detail.
Additionally, things like the Radius Servers and Method Lists are not displayed.
Its reverts back to normal once TACACS is enabled.
I suspect it is tied in to the fact that the GUI access is also not working with TACACS and hence it may be a privilege issue.
Here's the relevant parts of the config:
aaa new-model
aaa group server tacacs+ default
server name NW0001
server name NW1002
cache expiry 1
cache authorization profile admin_cache
cache authentication profile admin_cache
aaa group server radius HJstaff
server name nl0010
server name nl1010
aaa group server radius GFWEUR
server name nw0001
server name nw1002
aaa group server radius HJGuest
server name nl0010
server name nl1010
aaa authentication banner  CUnauthorised access is strictly prohibited.
aaa authentication fail-message  CAuthentication failed. Your password is incorrect or the AAA server is unavailable. Please try again or use local account.
aaa authentication login default group tacacs+ local-case
aaa authentication enable default group tacacs+ enable
aaa authentication dot1x HJstaff-Authentication group HJstaff
aaa authentication dot1x GFWEUR-Authentication group GFWEUR
aaa authentication dot1x HJGuest-Authentication group HJGuest
aaa authorization console
aaa authorization exec default group tacacs+ if-authenticated
aaa authorization commands 1 default group tacacs+ if-authenticated
aaa authorization commands 15 default group tacacs+ if-authenticated
aaa authorization network cwa_macfilter group HJGuest
aaa authorization credential-download default-webauth local
aaa accounting identity HJstaff-Accounting start-stop group HJstaff
aaa accounting identity GFWEUR-Accounting start-stop group GFWEUR
aaa accounting identity HJGuest-Accounting start-stop group HJGuest
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting system default start-stop group tacacs+
aaa cache profile admin_cache all
ip http server
ip http authentication local
ip http secure-server
I think the issue may be the ip http authentication local needs to be changed.
Any thoughts?
Roger
Overall Rating: 2 (1 ratings)
Rasika Nayanajith Mon, 03/03/2014 - 23:56
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Wireless
Hi Roger,
GUI of these platform are not good as it should be.
I would stick with CLI until it is get solid
Rasika
**** Pls rate all useful responses ****
