3750x Switch Inter-Vlan routing
Mar 4th, 2014
I would just like to find out what feature set the 3750x needs to be able to enable the "ip routing" command.
It currently has the LAN base feature set, which does not have this command.
Can it be done on the IP BASE feature set ? or the IP SERVICES set ?
