Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1928481members
1241947discussions
Community Activity
Upgrade Cat 9300 and 9500 No Reboot
Is there a better way to upgrade these yet?Obviously, I want to reboot after-hours. The install command still cannot be scheduled.install add file flash:cat9k_iosxe.17.09.05.SPA.bin activate commit prompt-level noneIf I do not do prompt-level none th...
Memory Utilization exceeds 85% on Cisco Nexus 3548 How to fix this ?
sw# show system resourcesLoad average:   1 minute: 0.33   5 minutes: 0.38   15 minutes: 0.31Processes   :   576 total, 1 runningCPU states  :   0.25% user,   1.00% kernel,   98.74% idle                CPU0 states  :   0.00% user,   0.00% kernel,   10...
Cisco Firepower 2130 Site to Site VPN Connection to AWS
Hello,   Good Day, Seeking help from you guys, currently I`m configuring Site to Site VPN connection from Cisco Firepower 2130 to AWS. I`m using the download configuration from AWS which is Cisco ASA 5500 9.X file, and I`m using Cisco Firepower 2130 ...
BGP using Layer 3 Switches
Hi All,I have 2 networks connected via OSPF. I need to route the connected networks to a third network via BGP.I noticed that BGP peering is established but no entry is visible on the routing table.Below is an extract of BGP config:router bgp 65200.1...
Ranjita by Level 1
  • 109 Views
  • 6 replies
9800 WLC-Same Vlans on multiple sites in SD-WAN setup
I have a 9800-CL in an SD-WAN setup. I have multiple sites that have the same Vlans at each site to make it easier to manage and remember.Ex:NorthSite: data-4, voice-5, wifi-6SouthSite: data-4, voice-5, wifi-6etc...My current WLC configuration has on...
GeorgeC71 by Level 1
  • 63 Views
  • 1 replies
Webex Question
I was recording my meeting & I saved it to my computer. Once it was ready I tried to watch it & it seems that it didn’t download correctly. I saved a video before no issues . I recorded another no issues. Is there a way to convert the file? I can vie...
nishhk2 by Level 1
  • 22 Views
  • 0 replies
BGP Log route updates
Hello,Does anyone know if there is a way to log bgp routes updates? Obviously there is a way to see adjacencies changes, but I am needing to see route updates by logging so I can send the output to a Syslog server?CheersSteven
ISE CoA Reauth for Aruba 2530
Hello everyone, Does anyone know the attributes to configure to make the CoA type reauth work on an Aruba 2530 switch (16.11)? I managed to make the CoA Disconnect and port bounce working but I don't have the solution for reauth and I need it for pro...
Catalyst9000 : EVPN VXLAN L2 Overlay (バックツーバック入力レプリケーション)設定
  はじめに 本ドキュメントでは、Catalyst においての、EVPN VXLAN L2 Overlay (バックツーバック入力レプリケーション)の設定について解説します。 本ドキュメントの検証にあたり、Cisco Modeling Labs ( CML )および cat9000v-17.11 を使用しています。 ※ CML、cat9000v-17.11 の取得および使用方法については、本ドキュメントでは扱いません   Back-to-Back L2 VNI Configuration...
