Warning message
wlc error
Mar 4th, 2014
We are getting following error when doing debug cleint <mac address> in wlc
*Dot1x_NW_MsgTask_3: Feb 26 17:40:48.750: c0:cb:38:97:df:db dot1x - moving mobile c0:cb:38:97:df:db into Connecting state
*Dot1x_NW_MsgTask_3: Feb 26 17:40:48.750: c0:cb:38:97:df:db Sending EAP-Request/Identity to mobile c0:cb:38:97:df:db (EAP Id 2)
*osapiBsnTimer: Feb 26 17:41:18.658: c0:cb:38:97:df:db 802.1x 'txWhen' Timer expired for station c0:cb:38:97:df:db and for message = M0
*dot1xMsgTask: Feb 26 17:41:18.658: c0:cb:38:97:df:db dot1x - moving mobile c0:cb:38:97:df:db into Connecting state
*dot1xMsgTask: Feb 26 17:41:18.658: c0:cb:38:97:df:db Sending EAP-Request/Identity to mobile c0:cb:38:97:df:db (EAP Id 3)
*dot1xMsgTask: Feb 26 17:41:27.058: c0:cb:38:97:df:db Failure sending WPA EAPOL-Key due to invalid state 0 to mobile c0:cb:38:97:df:db
*dot1xMsgTask: Feb 26 17:41:27.058: c0:cb:38:97:df:db Unable to send WPA key to mobile c0:cb:38:97:df:db
Machine is Windows 7, but strange is if the user tried after 2-3 min, It is working fine.
WLC version: 7.4.121.0 & Hw-Model 5508
We are using 802.1x & WPA2 encryption AES & TKIP.
Pls note: we are facing this error/problem in corporate SSID, guest SSID without WPA/TKIP is working fine
Br..
Overall Rating: 5 (1 ratings)
Stephen Rodriguez Tue, 03/04/2014 - 05:45
  • Purple, 4500 points or more
If you are doing WPA2, your encryption shoudl only be AES.
Try going into the WLAN and disabline TKIP as an encryption method.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Sandeep Choudhary Wed, 03/05/2014 - 04:14
  • Cisco Designated VIP,
    2017 Wireless
Hi subho,
check your advanced eap timers on the WLC.  Run "show advanced eap" from the CLI.  It feels like you need to increase your EAP Request Identity timeout.
Try this:
Config wps client-exclusion all disable
Config advanced eap identity-request-timeout 30
Config advanced eap identity-request-retries 10
Config advanced eap request-timeout 30
Config advanced eap request-retries 10
config 802.11b disable network
config 802.11b preamble long
config 802.11b enable network
Dont forget to rate helpful posts.
subhojithalder198 Wed, 03/05/2014 - 04:26
I have already teied this, but not working
I saw the same in your earlier post
Br/Subhojit
Scott Fella Wed, 03/05/2014 - 05:21
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 Wireless
Post your show wlan
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
subhojithalder198 Thu, 03/06/2014 - 06:38
pls find the capture as attached
pls suggest further
WLAN Identifier.................................. 1
Profile Name..................................... wifi-dc-data
Network Name (SSID).............................. wifi-dc-data
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Enabled
Network Admission Control
  Client Profiling Status ....................... Disabled
   DHCP ......................................... Disabled
   HTTP ......................................... Disabled
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
Number of Active Clients......................... 1
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 43200 seconds
User Idle Timeout................................ 300 seconds
User Idle Threshold.............................. 0 Bytes
NAS-identifier................................... ****** Hostname***
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ wifi-data
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
mDNS Status...................................... Enabled
mDNS Profile Name................................ default-mdns-profile
DHCP Server...................................... Default
DHCP Address Assignment Required................. Enabled
Static IP client tunneling....................... Disabled
PMIPv6 Mobility Type............................. none
Quality of Service............................... Silver
Per-SSID Rate Limits............................. Upstream      Downstream
Average Data Rate................................   0             0
Average Realtime Data Rate.......................   0             0
Burst Data Rate..................................   0             0
Burst Realtime Data Rate.........................   0             0
Per-Client Rate Limits........................... Upstream      Downstream
--More-- or (q)uit
Scan Defer Priority.............................. 5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Disabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Drop
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ **** IP ***
   Accounting.................................... **** IP ***
      Interim Update............................. Disabled
   Dynamic Interface............................. Disabled
   Dynamic Interface Priority.................... wlan
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   FT Support.................................... Disabled
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Disabled
      WPA2 (RSN IE).............................. Enabled
         TKIP Cipher............................. Disabled
         AES Cipher.............................. Enabled
                                                               Auth Key Management
         802.1x.................................. Enabled
         PSK..................................... Disabled
         CCKM.................................... Disabled
         FT-1X(802.11r).......................... Disabled
         FT-PSK(802.11r)......................... Disabled
         PMF-1X(802.11w)......................... Disabled
         PMF-PSK(802.11w)........................ Disabled
      FT Reassociation Timeout................... 20
      FT Over-The-DS mode........................ Enabled
      GTK Randomization.......................... Disabled
      SKC Cache Support.......................... Disabled
      CCKM TSF Tolerance......................... 1000
   WAPI.......................................... Disabled
   Wi-Fi Direct policy configured................ Disabled
   EAP-Passthrough............................... Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   FlexConnect Local Switching................... Disabled
   flexconnect Central Dhcp Flag................. Disabled
   flexconnect nat-pat Flag...................... Disabled
   flexconnect Dns Override Flag................. Disabled
   FlexConnect Vlan based Central Switching ..... Disabled
   FlexConnect Local Authentication.............. Disabled
   FlexConnect Learn IP Address.................. Enabled
   Client MFP.................................... Disabled
   PMF........................................... Disabled
   PMF Association Comeback Time................. 1
   PMF SA Query RetryTimeout..................... 200
   Tkip MIC Countermeasure Hold-down Timer....... 60
AVC Visibilty.................................... Disabled
AVC Profile Name................................. None
Flow Monitor Name................................ None
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Assisted Roaming Prediction Optimization......... Disabled
802.11k Neighbor List............................ Disabled
802.11k Neighbor List Dual Band.................. Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
Mobility Anchor List
WLAN ID     IP Address            Status
802.11u........................................ Disabled
MSAP Services.................................. Disabled
Scott Fella Tue, 03/04/2014 - 05:59
  • Hall of Fame,
    2017 Wireless
Steve is right on the money!!!
Trending Topics - Security & Network
