CUCM 8.6.2a to 8.6.2a(su3)
Mar 4th, 2014
Is this considered a refresh or L2L upgrade? It's a bit confusing searching on it. I want to upgrade our CUCM 8.6.2a cluster of 4 CUCM's and was trying to figure out if I can upload the files in advance to save time and reboot to the new version during a maintenance window? All I read is that you can "upgrade during business operations without affecting service on an L2L upgrade but not for a refresh upgrade.
I need to also upgrade the UCCX servers and CUPS server during this upgrade process also...
Chris Deren Tue, 03/04/2014 - 06:15
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
This is just a minor upgrade, this does not require a refresh cop as you would have already done it when going to base 8.6 (if you upgraded).
Chris
tim-griffin Tue, 03/04/2014 - 06:19
The question is - can the servers be upgraded during business hours in the standby partition and then rebooted during off hours?
Chris Deren Tue, 03/04/2014 - 06:23
  • Hall of Fame,
Yes, if that is what you want to do. I still typically recommend doing this after hours especially on busy systems though.
Chris
Rob Huffman Tue, 03/04/2014 - 06:18
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
    2017 IP Telephony, Unified Communications
Hi Tim,
This would be an L2 upgrade A Refresh upgrade would
be a pre-8.6 to 8.6 or later.
You should be able to do the upgrade and use the "do not switch version"
and then use the "switch version" during the upgrade window. Don't forget
to keep track of any user changes done during the upgrade to switch version
intervening time frame.
Cheers!
Rob
"May your heart always be joyful
And may your song always be sung
May you stay forever young "
- Dylan
