Warning message
HA configuration between (2) 5508 controllers with 12 licenses each
Answered Question
Mar 4th, 2014
Hello
Can HA be configured on Cisco 5508controllers with 12 licenses each. Is there a minimum license requirement?
Product Version.................................. 7.4.121.0
Bootloader Version............................... 1.0.1
Field Recovery Image Version..................... 6.0.182.0
sMc
Correct Answer by Scott Fella about 3 years 5 months ago
Make sure you are running the latest FUS image... seem's like you are not by looking at this:
Upgrade to FUS 1.9.0.0.. here is the release notes:
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/fus_rn_OL-31390-01.pdf
Download the FUS here.... the process will take around 35-45 minutes in which you will not be able to acess the WLC.  You should console into the WLC to see the progress of the upgrade.
http://software.cisco.com/download/release.html?mdfid=283848165&flowid=24841&softwareid=284364857&release=1.9.0.0&relind=AVAILABLE&rellifecycle=&reltype=latest
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Correct Answer by Sandeep Choudhary about 3 years 5 months ago
just to add:
You either need the  standby controller (either WLC HA sku controller or a WLC5508 with 50 AP license or more) to run HA AP SSO.
Primary controller : With enough license (Example:100 AP license)
Secondary or standby Controller:  HA-SKU license or a WLC5508 with 50 AP license
Hope this is more clear.
Dont forget to rate helpful posts
Here is the part number so you can compare the cost: AIR-CT5508-HA-K9
Scott
No specific hardware if you have one with 50 licneses... but it might be cheaper to get an HA sku WLC.
Scott
If you have less than 12 AP's, just follow what Sandeep posted and assign the primary and secondary WLC's to each AP.
Scott
For true redundancy, you either can get another WLC with the same # of access point licenses, but if you have more than 50 AP's, then just either look at the cost for an HA sku wlc compared to the cost of adding licenses to get to 50 AP.
Scott
Just adding to scott:
if you have 2 wlc with each 12 ap licence then you can configure AP failover:
Local on AP
Wireless > Access Points > All APs > Select AP > High Availability Configuration
or
Global
WIRELESS >Global Configuration
check here:
http://rscciew.wordpress.com/2014/01/22/ap-failover/
regards
Here you go.
http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1130-ag-series/qa_c67-714540.html
Q.
I already have a spare controller. Can I convert that controller to the standby controller?
A. Yes. Customers need to upgrade their controller software to Release 7.3. They can then convert the spare to a standby controller using the command-line interface or GUI.
It is important to note that on the Cisco 5508, the controller needs to have at least 50 access point licenses in order to be able to convert the controller to the standby controller for the wireless LAN.
Scott
Minimum is 50 AP license to run HA.
Scott
Overall Rating: 5 (9 ratings)
Correct Answer
Scott Fella Tue, 03/04/2014 - 09:07
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Scott
Correct Answer
Scott Fella Tue, 03/04/2014 - 09:08
  • Hall of Fame,
    2017 Wireless
Here you go.
Q.
Scott
Steve Coady Tue, 03/04/2014 - 09:15
Scott
Thank you for the reply
What other options do I have for failover/standby between controllers?
sMc
Correct Answer
Sandeep Choudhary Tue, 03/04/2014 - 09:24
  • Purple, 4500 points or more
    2017 Wireless
Local on AP
or
Global
check here:
regards
Correct Answer
Scott Fella Tue, 03/04/2014 - 09:26
  • Hall of Fame,
    2017 Wireless
Scott
Correct Answer
Scott Fella Tue, 03/04/2014 - 09:27
  • Hall of Fame,
    2017 Wireless
Scott
Steve Coady Tue, 03/04/2014 - 09:36
Sandeep
Thank you for the reply.
I new of the High availability option on the AP's. Due to the push to use HA, I was not sure if the
controllers had another failover option
sMc
Steve Coady Tue, 03/04/2014 - 09:40
Hello
Is there a specific HA license that has to be purchased or is HA automatically available if the minimum License
requirement is met?
sMc
Correct Answer
Scott Fella Tue, 03/04/2014 - 09:44
  • Hall of Fame,
    2017 Wireless
Scott
Correct Answer
Scott Fella Tue, 03/04/2014 - 09:46
  • Hall of Fame,
    2017 Wireless
Scott
Correct Answer
Sandeep Choudhary Tue, 03/04/2014 - 10:31
    2017 Wireless
just to add:
Correct Answer
Scott Fella Tue, 03/04/2014 - 10:44
  • Hall of Fame,
    2017 Wireless
Scott
Trending Topics - Security & Network
