Warning message
Add timestamp using variable
Answered Question
Mar 4th, 2014
Date stamp was easy to create using a custom format variable, but I cannot see how to do the same for a time stamp.  I would need a time stamp format without colons or slashes that would be rejected as a filename.
Can a custom format Time variable be created?  Or has anyone created a job which adds timestamps to files?   I can script it of course, but looking for a clean all purpose time stamp process.
thanks
Correct Answer by Marc Clasby about 3 years 5 months ago
For a file stamp the tidal system date is easy solution (you can use any date type variable)
Tidal Variables
Use system time (typically you add via variable button)
Take and remove :
and you will just get the numbers
use that as a tag to job
if you use Powershell you could use the get-date function as well depending ans format it depending on what you want to do.i
Marc
Overall Rating: 5 (2 ratings)
Correct Answer
Marc Clasby Tue, 03/04/2014 - 12:17
Tidal Variables
Take and remove :
Marc
Bill Slobodnik Tue, 03/04/2014 - 13:39
Thanks Marc.   I did not realize I could actually edit the variable format once it was added to the job.  Too easy!
