The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally. New Here? Click here to learn more and get started.
Cisco Community is an active and collaborative place to learn more about our products and ask questions of peers and Cisco experts! Check out some of the most popular conversations happening right now!
Greetings,The customer has 2 BGP links towards us, separated dual homed (PE1-CE1 & PE2-CE2), who is asking why they are receiving traffic on link No.1 even they have already configured route-map to deny all routes imported from & exported to PE1. The...
Hi guys,i'm using the latest version of packet tracer (8.0.1) but still getting this problem and i really need the fileif anyone knows how to open it please help !!
A third party has configured their end of the VPN using an IP range ( I believe it's a fortinet as I think it's the only vendor that can do ranges) So they have configured the encryption domain like so: 10.20.5.23-10.20.5.25I don't believe this is po...
I have upgraded cisco NCS-5504 router . Router was successfully upgraded but all the line cards are not showing. In platform command type is unknown and state is SW_Inactive.Regards Salman
Hi ALL,I have setup a lab in CML for testing multicast using Auto-RP but I cant see traffic flowing from the source to the receivers . I can see the (S,G) entry in the first hop router and the (*,G) entry in the RP .Appreciate any feedback Thanks,Fra...
Dear all,I am configuring a network cfomposed of 4 VLANs with the following devices:- NetGate 6100 Firewall- A Cisco 2951 Router- Ciscon 2960 SwitchVLANs and DHCP were configured on the 2951 router.Note that NAT function is handled by the Firewall.Af...
Ask Me Anything Event Welcome to the Cisco Community Ask Me Anything conversation. Submit your questions from Wednesday, April 10, 2024 through Wednesday, April 24, 2024. Our Community VIPs, Kathy New and Maren Mahoney will be waiting to assist you ...
We have implemented 802.1x with machine certificate authentication.The certificate validation is via OCSP and the question is does Cisco ISE support connection to OSCP via a Web Proxy? The assumption is that the connection would be using the system p...
Hi all,I am thinking of purchasing asr1002-hx and would like to make sure my understanding is right.I need crypto, vrf's,dmvpn, mpls, ospf, bgp.. full feature set..What I understand that I need is following :ASR1002HX-IPSECHW= Cisco ASR1002-HX Crypto...
Hi Guys, I will be using IW9167 in UWRB mode for an AGV use case but I am stuck what external antenna to use. I will be placing my AP at the metal column about 6 to 7 meters from floor. Not sure which antenna is best either omnidirectional or directi...
Is there a way to assign a contact center agent license to a user using Webex API?When I list the available licenses I do not see any of the contact center license.https://developer.webex.com/docs/api/v1/licenses/list-licensesWhen I use the API to ge...
So I've been working on my project and I've implemented vlans nad also router stick.Now I want to block connections between vlans that are not same with extended access list but something does not work..Here are the commands that I've writtenip acces...
Hi , Good day. I need some help to verify if there is any configuration issue from my end. Basically i have a registered LGW to the webex calling . The incoming call is working fine , but the outgoing call is getting the following error Outgoing ca...
I have an EVE-NG lab that consists of a Panorama, 1 FW, and 4 ISE nodes (see lab.jpg attached). The Lab ISE nodes are running 3.2 patch 5 and panorama and Firewall is running 10.2.7-h3. In reading the 3.2 and 3.1 admin guides they both state in the...
