Warning message
Connecting "fast ethernet" to "ethernet" is not working!
Answered Question
Mar 5th, 2014
Hey there,
I connected "FE 0/1" (cisco 1841) to "Ethernet 1/0" ( NM-4E module in 2651 router). Both interfaces' status are up but their line protocol is down.
I sat both their speed to 10Mbps and their duplux to full but no luck.
Is this because i am using a straight-throught cable? According to my understanding all cisco routers uses "Auto-Mdix" feature which eleminates the need for cross-over cables.
Abdul,
Correct Answer by cadet alain about 3 years 5 months ago
Auto mdix needs autonegotiation and not all devices or modules  support this feature.
Alain
Overall Rating: 5 (4 ratings)
Jon Marshall Wed, 03/05/2014 - 04:22
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Abdul
Most switches support that feature but not necessarily routers. If you were using a switch module in the router then it would probably support it but i'm not sure the onboard ports do.
Jon
Correct Answer
cadet alain Wed, 03/05/2014 - 04:23
  • Purple, 4500 points or more
Alain
Umesh Shetty Wed, 03/05/2014 - 09:52
HI Alain,
Another good peice of information, I was not really aware of this. I was under the impression that auto mdix works and is independent of speed/duplex settings. There definitely must be a reason behind auto mdix needing auto nego ON. If you could put some light on that too please
Umesh
Abdullah Net Wed, 03/05/2014 - 21:12
Alain,
You are right. As it turns out, the "NM-4E" module is very very old and it lacks autonegotiation feature thus no auto-mdix.
I used cross-over cables and everything works fine now.
Abdul,
Dragan Ilic Wed, 03/05/2014 - 04:31
  • Silver, 250 points or more
Do you see something in log?
As I understand you have L2 issue - have you tried with static "half-duplex" on both sides?
HTH,
Dragan
Richard Burts Wed, 03/05/2014 - 05:36
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Alain reminds us that auto mdix needs autonegotiation and Abdul tells us that he is hard coding the speed and duplex. I think that the simple thing is to try a crossover cable and see if the connection works with that.
Rick
