Sean O'Garza
john.garza
                   I have several Cisco 1040 Series and 1260 Series wireless access points and the question I have is, is it possible to make a wireless conneciton to an AT&T or Verizon MiFi  from my Cisco APs ?   Would you somehow make a "bridge" connection or try use the WiFi's client capability somehow ?   Thanks Guys.
5 Replies 5
Scott Fella
Not really. There is a WGB mode, but I don't thing that will work for you.
-Scott
Stephen Rodriguez
You could probably use the WGB mode of the aIOS AP to connect to your MiFi.
but, why are you looking to go that route?
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Scott Fella
Your better off getting a Ethernet converter from a local electronics store and using that.
-Scott
Scott, thanks for the info.  I'm not quite sure what you mean by getting an Ethernet Converter, is this something that would connect wirelessly to the MiFi and it has a LAN connection that I can then get into a Cisco Switch ?
Something like this
http://www.buffalotech.com/products/wireless/ethernet-bridges/airstation-n300-4-port-dual-band-wireless-ethernet-bridge
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
