Warning message
Confirming CLI commands before copying?
Answered Question
              Hi All,
                   Is there a way to confirm the cli commands inputted into a Nexus5k (NX-OS) Ver 4.1(3) N1(1), before copying it to start. The JunOS has a "commit check" command that will give a heads up if the commands you are about to put in are going to hose your network. The "checkpoint" function will get me back to an operational state, but, I would rather not have to dance while the network comes back to life.
Thanks All,
              Ron Clifford
Correct Answer by Reza Sharifi about 3 years 5 months ago
Hi Ron,
unfortunately, commit check, rollback 1,2, 3, etc... are all part of Junos and not IOS or Nexus OS. With Nexus OS, as soon as you type a command and press enter, it will take effect just like the regular IOS.
Cisco is trying to add great features that Juniper has, but they still have a long way to go, because they have too many different OSs.
Correct Answer by cadet alain about 3 years 5 months ago
IOS-XR implements the commit feature and checks the validity of the config and it seems NX-OS does the same
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/configuration/guide/cli_rel_4_0_1a/CLIConfigurationGuide/sm_rollback.html#wp1076261
Alain
Correct Answer by paul driver about 3 years 5 months ago
Hello
Cisco also have a rollback back feature.This is initiated using the archive command
Once setup it will rollback any applied config if it isn't confirmed within a specified time period- I personally think it better than a schedule reload
However on certain iOS and hardware eg 6509-6513's iI have found it seems to not work as it should also am not aware of any cisco feature that will test your config is good prior to implementing as junos does.
Res
Paul
Overall Rating: 5 (3 ratings)
Correct Answer
paul driver Wed, 03/05/2014 - 09:46
  • Green, 3000 points or more
Hello
Res
Paul
Correct Answer
Reza Sharifi Wed, 03/05/2014 - 10:35
  • Cisco Designated VIP,
    2017 LAN
Hi Ron,
