The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally. New Here? Click here to learn more and get started.
Cisco Community is an active and collaborative place to learn more about our products and ask questions of peers and Cisco experts! Check out some of the most popular conversations happening right now!
how can we determine how much traffic passes through the interface vlan in the Nexus switches,the command (show interface vlan ) doesn't give the needed same as the catalyst,also, (show interface vlan counter) the values we can't read!
Unveiling the 1804-886-0886 Hawaiian 헔헶헿헹헶헻헲혀 Low Fare CalendarIntroduction:In the world of air travel, finding the best deals can feel like searching for a needle in a haystack. However, Hawaiian 헔헶헿헹헶헻헲혀 has simplified this process with its innova...
Hi Guys,We're having issues with our RADIUS authentication. We just keep getting login failed when trying to connect to our VPN. We've run an authentication test in ASDM and that works fine so not sure where our issue lies. I've pulled out our config...
hello all ,recently i tried to configure VPN site to site with certificate authentication type, i got the certificate signed by a third party autority , and when i did the debugs i got this log :CRYPTO_PKI: bitValue of KEY_USAGE = a0PKI[7]: CRYPTO_PK...
C9120AX-C was previously joined to the controller, but for some reason it stopped working. Upon checking it disappeared from the controller. The last join attempt stats below
I installed ThousandEyes on my C9407 switch. It seems to be working but I keep getting the following message in the switch logs%IM-5-IOX_INST_NOTICE: R0/0: ioxman: IOX SERVICE teyes LOG: Error posting results to https://data1.agt.thousandeyes.com: HT...
Hello ,We are having problem with one AP to join the WLC , all others successfully the controlle. the console output is :[*03/19/2024 09:08:50.0003] CAPWAP State: DTLS Setup[*03/19/2024 09:08:50.0035] dtls_process_packet: DTLS Error: 1040[*03/19/2024...
I have an ISR 1K with DUAL ISPs (Dialer0 & Cellular) My intention was to implement something similar to this article: https://learningnetwork.cisco.com/s/question/0D53i00000Kt1XYCAZ/nat-failover-with-dual-isp-on-a-router-configuration-example?t=17103...
Hi all , with Velocity-Templates there was the possibility to add interactive or exec commands to the template which works fine.Now customer wants to use Jinja2-Template, seems this MODE_ENABLE and INTERACTIVE is not possible there, is there another ...
Hi,Is it possible to have multiple CBW Masters on the same network? It appears that the MAC address used is static and hence two is an issue?Many thanksTom.
