Warning message
IPS-4260 Where is the Flash?
Mar 5th, 2014
Hi!
So, I have a Cisco IPS-4260 that is not finding a boot device.. My research indicates the "IPS 4260 uses a flash device for storage rather than a hard-disk drive"
             My question is, Where is the flash device and what exactly is it? I don't see any ports, plugs or a space for a compact flash card on my device...
Any help will be appreciated!
Chuck
Saurav Lodh Thu, 03/06/2014 - 02:21
  • Gold, 750 points or more
Its internal flash not external flash
Pageplayer Thu, 03/06/2014 - 04:38
Thanks for your reply,
Yes, I know that much,  but where/what is it inside the unit? I opened it up, but not sure where it is. I just acquired the unit and Im wondering if it was removed
Pageplayer Thu, 03/06/2014 - 15:18
Anyone?
schematic of the board? Diagram? Photo of the flash module?
nburky001 Sun, 04/13/2014 - 21:30
I also have the same issue, running a recovery image via TFTP errors as no HD found.
Can anyone shed any more light on this? Something to physically inspect on Motherboard, or BIOS setting?
Alternatively, will plugging in an external USB hard drive work as well? (This is a lab box for testing etc, no production usage).
This is the end snippet of the recovery procedure:
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
RAMDISK: Compressed image found at block 0
Freeing initrd memory: 24144k freed
VFS: Mounted root (ext2 filesystem) readonly.
Freeing unused kernel memory: 132k freed
init started:  BusyBox v1.00-rc1 (2008.07.12-04:16+0000) multi-call binary
EXT2-fs warning: checktime reached, running e2fsck is recommended
ls: /proc/ide/hd*: No such file or directory
Recovery version 1.21
Started on Mon Apr 14 03:54:43 UTC 2014
Full system recovery
Making filesystems on none
Abort: mke2fs -j none
Please press Enter to activate this console.
Poonam Garg Sun, 04/13/2014 - 23:42
  • Silver, 250 points or more
In IDS-4215, compact flash drive is under the hard-disk drive, it might be same in 4260 as well .
Pageplayer Mon, 04/14/2014 - 04:42
Cisco touted this device for not having a hdd that could fail, and I couldn't find an internal slot for a flash card. I'm thinking it uses a NAND Flash component?
nburky001 Mon, 04/14/2014 - 18:54
Just to confirm, adding an old IDE hard disk (8GB) with standard IDE cable works fine.
Just update BIOS to allow boot from hard disk, and you'll find the IDE cable on motherboard underneath one of the add-in cards (just lift it up with blue levers).
Cheers.
Pageplayer Tue, 04/29/2014 - 14:01
Hi nburky,
Any chance you could post the procedure to install the files on a HDD? I just got around to messing around with this again, and got a HDD to boot to a C: prompt by just plugging it in.. But now I don't have a clue what to do next.
Chuck
