Warning message
Adding another 5505 to the Network.......
Answered Question
Mar 5th, 2014
Hello all I could use some help before I scream
I have at my main office 5510.  I have 4 remote offices with 5505.  These 4 office connect L2L VPN to my main office with NO problems and have for a couple years.
We recently added a 5th office with yet another 5505.  So I am doing the same thing having the new office VPN to the main office.  But for the life of me I cannot seem to get it to connect.  I have used the same set up on the NEW office as I did all the old office but for whatever reason I cannot establish a tunnel / connection.
Here are the results from a couple commands:
Result of the command: "show crypto isakmp sa"
There are no isakmp sas
Result of the command: "show crypto ipsec sa"
There are no ipsec sas
I am kinda lost as to what to do now.......
Thanks for any help.
Correct Answer by jjohnston1127 about 3 years 5 months ago
One thing that initially alerts me is the ACLs for the encryption domain and nat exemption.  Is the remote site really at 192.198.10.0/24 or is it 192.168.10.0/24?
access-list 106 extended permit ip 192.168.90.0 255.255.255.0 192.198.10.0 255.255.255.0
access-list nonat extended permit ip 192.168.90.0 255.255.255.0 192.198.10.0 255.255.255.0
Other than that, the configuration, to me, looks good assuming you have the same ISAKMP and IPSEC configuration on the 5510 side.
Overall Rating: 5 (1 ratings)
jjohnston1127 Wed, 03/05/2014 - 12:07
  • Silver, 250 points or more
I would imagine you have a phase 1 mismatch or you have not configured the tunnel-group on the 5510 for the new site.  Hard to say w/o the configurations.
Please post the relevant configuration from the new ASA 5505 and post your ASA 5510 configuration.
toddyboman Wed, 03/05/2014 - 12:24
Here is the 5505
: Saved
ASA Version 8.2(5)
hostname ********
enable password mrNAzLB3WoDGll7l encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
 switchport access vlan 12
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
 nameif inside
 security-level 100
 ip address 192.168.90.1 255.255.255.0
interface Vlan12
 nameif outside
 security-level 0
 pppoe client vpdn group AT&T
 ip address pppoe setroute
ftp mode passive
clock timezone CST -6
clock summer-time CDT recurring
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group network outbound
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1492
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list nonat
nat (inside) 1 0.0.0.0 0.0.0.0
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.90.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set MM esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map outside_map 90 match address 106
crypto map outside_map 90 set peer 222.222.222.22
crypto map outside_map 90 set transform-set MM
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 1
 authentication pre-share
 encryption 3des
 hash sha
 group 2
 lifetime 43200
crypto isakmp policy 10
 encryption 3des
 hash sha
 group 2
 lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
vpdn group ATT request dialout pppoe
vpdn group ATT localname [email protected]
vpdn group ATT ppp authentication pap
vpdn username [email protected] password *****
dhcpd dns 208.67.222.222 208.67.220.220
dhcpd auto_config outside
dhcpd address 192.168.90.5-192.168.90.254 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
webvpn
tunnel-group 222.222.222.22 type ipsec-l2l
tunnel-group 222.222.222.22 ipsec-attributes
 pre-shared-key ****
tunnel-group 77.77.777.777 type ipsec-l2l
tunnel-group 77.77.777.777 ipsec-attributes
 pre-shared-key ****
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:748218d8f392a0ead093b8ebd225d599
: end
5510
: Saved
ASA Version 8.0(5)
hostname MC
names
nameif outside
security-level 0
pppoe client vpdn group cl
nameif inside
security-level 100
ip address 192.168.10.1 255.255.255.0
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
ip address 192.168.2.5 255.255.255.0
management-only
boot system disk0:/asa805-k8.bin
ftp mode passive
access-list inside_mpc extended permit tcp any any inactive
access-list nonat extended permit ip 192.168.10.0 255.255.255.0 192.168.30.0 255.255.255.0
access-list nonat extended permit ip 192.168.10.0 255.255.255.0 192.168.20.0 255.255.255.0
access-list nonat extended permit ip 192.168.10.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list nonat extended permit ip 192.168.10.0 255.255.255.0 192.168.40.0 255.255.255.0
access-list nonat extended permit ip 192.168.10.0 255.255.255.0 192.168.90.0 255.255.255.0
access-list 101 extended permit ip 192.168.10.0 255.255.255.0 192.168.20.0 255.255.255.0
access-list 100 extended permit ip 192.168.10.0 255.255.255.0 192.168.30.0 255.255.255.0
access-list 102 extended permit ip 192.168.10.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list 105 extended permit ip 192.168.10.0 255.255.255.0 192.168.40.0 255.255.255.0
access-list 106 extended permit ip 192.168.10.0 255.255.255.0 192.168.90.0 255.255.255.0
pager lines 24
logging enable
logging buffered debugging
logging from-address [email protected]
logging recipient-address [email protected] level alerts
logging debug-trace
mtu outside 1492
mtu inside 1500
mtu management 1500
no failover
asdm image disk0:/asdm-631.bin
asdm history enable
arp timeout 14400
global (outside) 101 interface
nat (inside) 101 0.0.0.0 0.0.0.0
route outside 192.168.1.0 255.255.255.0 209.142.191.13 1
route outside 192.168.20.0 255.255.255.0 209.142.191.13 1
route outside 192.168.30.0 255.255.255.0 209.142.191.13 1
route outside 192.168.40.0 255.255.255.0 209.142.191.13 1
route outside 192.168.90.0 255.255.255.0 209.142.191.13 1
aaa authentication ssh console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 management
http 192.168.10.0 255.255.255.0 inside
crypto ipsec transform-set KV esp-3des esp-sha-hmac
crypto ipsec transform-set Macon esp-3des esp-sha-hmac
crypto ipsec transform-set Shelby esp-3des esp-sha-hmac
crypto ipsec transform-set Han esp-3des esp-sha-hmac
crypto ipsec transform-set Moberly esp-3des esp-sha-hmac
crypto map outside_map 10 match address 102
crypto map outside_map 10 set peer 10.10.10.10
crypto map outside_map 10 set transform-set Shelby
crypto map outside_map 20 match address 101
crypto map outside_map 20 set peer 20.20.20.20
crypto map outside_map 20 set transform-set Macon
crypto map outside_map 30 match address 100
crypto map outside_map 30 set peer 30.30.30.30
crypto map outside_map 30 set transform-set KV
crypto map outside_map 40 match address 105
crypto map outside_map 40 set peer 40.40.40.40
crypto map outside_map 40 set transform-set Han
crypto map outside_map 90 set peer 222.222.222.222
crypto map outside_map 90 set transform-set Moberly
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
management-access inside
vpdn group cl request dialout pppoe
vpdn group cl localname xxxxxxxx
vpdn group cl ppp authentication pap
vpdn username xxxxxxxx password ********* store-local
dhcpd address 192.168.10.3-192.168.10.50 inside
dhcpd enable inside
username admin password vx8BkOWfWwvYuBKw encrypted
tunnel-group DefaultL2LGroup ipsec-attributes
pre-shared-key *
tunnel-group 20.20.20.20 type ipsec-l2l
tunnel-group 20.20.20.20 ipsec-attributes
pre-shared-key *
tunnel-group 30.30.30.30 type ipsec-l2l
tunnel-group 30.30.30.30ipsec-attributes
pre-shared-key *
tunnel-group 40.40.40.40 type ipsec-l2l
tunnel-group 40.40.40.40 ipsec-attributes
pre-shared-key *
tunnel-group 10.10.10.10 type ipsec-l2l
tunnel-group 10.10.10.10 ipsec-attributes
pre-shared-key *
tunnel-group 222.222.222.222 type ipsec-l2l
tunnel-group 222.222.222.222 ipsec-attributes
pre-shared-key *
class-map type regex match-any domainblocklist1
match regex domainlist1
class-map type inspect http match-all BlockDomainsClass
match request header host regex class domainblocklist1
class-map type regex match-any URLBlockList
match regex urlist4
class-map type inspect http match-all BlockURLsCLass
match request uri regex class URLBlockList
class-map type inspect http match-all AppHeaderClass
match request header regex applicationheader regex applicationheader
class-map httptraffic
match access-list inside_mpc
parameters
policy-map type inspect http http_inspection_policy
parameters
  protocol-violation action drop-connection
match request method connect
  drop-connection log
class AppHeaderClass
  drop-connection log
class BlockDomainsClass
  reset log
class BlockURLsCLass
  reset log
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect icmp
policy-map inside-policy
class httptraffic
service-policy inside-policy interface inside
Cryptochecksum:ab762e380a0b975c824ad0037acf0f72
: end
asdm history enable
Correct Answer
jjohnston1127 Wed, 03/05/2014 - 12:32
toddyboman Wed, 03/05/2014 - 13:58
Good Grief... Don't I feel dumb.  I will make that change tonight and HOPEFULLLY that will fix it.
I will let you know.
Thanks!!!!!
toddyboman Wed, 03/05/2014 - 20:59
So glad this was simple fix.....but feel so dumb to have over looked something so simple.
Thanks for the help!
jjohnston1127 Wed, 03/05/2014 - 21:02
Hey,  typos happen! I've had my fair share over the years. Glad it was something simple rather than hours of troubleshooting.
Take care.
