Warning message
OSPF ASBR and ABR
Mar 5th, 2014
I have a 7206 that was redistributing static and connected subnets into OSPF in area 0.  I have since done some tidying up and have stopped the redistribution.  The router has interfaces in area 0.0.0.0 and also 0.7.0.1, therefore making it an ABR, however, when I do a 'sh ip ospf' the router is saying the following:
It is an area border and autonomous system boundary router
I'm surprized that it still thinks that it is an ASBR since all redistribution has been removed - no static, connected or any other routing protocol being redistributed.
I though that it might be "stuck" in this state since it was a an ABR and ASBR, therefore, I did a "clear ip ospf process" however, that didn't fix it.
Is there a reason for the router still thinking that it is a ASBR or should I look at reloading the router to clear it?
Here's the output from a show ip ospf command:
sh ip ospf 10
Routing Process "ospf 10" with ID x.x.x.x
Start time: 00:00:16.216, Time elapsed: 1y31w
Supports only single TOS(TOS0) routes
Supports opaque LSA
Supports Link-local Signaling (LLS)
Supports area transit capability
Redistributing External Routes from,
Router is not originating router-LSAs with maximum metric
Initial SPF schedule delay 5000 msecs
Minimum hold time between two consecutive SPFs 10000 msecs
Maximum wait time between two consecutive SPFs 10000 msecs
Incremental-SPF disabled
Minimum LSA interval 5 secs
Minimum LSA arrival 1000 msecs
LSA group pacing timer 240 secs
Interface flood pacing timer 33 msecs
Retransmission pacing timer 66 msecs
Number of external LSA 1021. Checksum Sum 0x55AA38D
Number of opaque AS LSA 0. Checksum Sum 0x000000
Number of DCbitless external and opaque AS LSA 0
Number of DoNotAge external and opaque AS LSA 0
Number of areas in this router is 2. 2 normal 0 stub 0 nssa
Number of areas transit capable is 0
External flood list length 0
IETF NSF helper support enabled
Cisco NSF helper support enabled
    Area BACKBONE(0.0.0.0)
        Number of interfaces in this area is 4 (1 loopback)
        Area has no authentication
        SPF algorithm last executed 01:25:17.896 ago
        SPF algorithm executed 4 times
        Area ranges are
        Number of LSA 80. Checksum Sum 0x403239
        Number of opaque link LSA 0. Checksum Sum 0x000000
        Number of DCbitless LSA 0
        Number of indication LSA 0
        Number of DoNotAge LSA 0
        Flood list length 0
    Area 0.7.0.1
        Number of interfaces in this area is 6
        SPF algorithm last executed 01:25:17.904 ago
        Area ranges are
        Number of LSA 44. Checksum Sum 0x210C38
        Flood list length 0
Any advise would be greatly appreciated.
Jonathan.
Overall Rating: 5 (1 ratings)
Peter Paluch Wed, 03/05/2014 - 14:50
  • Cisco Employee,
Hi Jonathan,
Is this router perhaps configured with default-information originate? If yes then that is the reason why your router treats itself as an ASBR. Injecting a default route into OSPF thanks to this command is done by originating an LSA-5 with the 0.0.0.0/0 network, and by definition, any router originating LSA-5 is an ASBR.
Best regards,
Peter
jonathan johnson Wed, 03/05/2014 - 15:02
Hi Peter,
Yes, it is configured with default-information originate.  I wasn't aware that having this configured would make the router an ASBR, but now knowing how it injects the default route - it makes sense.
Perhaps I need to use BGP to send the default route to my other routers.
I need this router to be an ABR so that I can do summarization.
Thanks for assistance Peter.
Jonathan.
Peter Paluch Wed, 03/05/2014 - 15:09
  • Cisco Employee,
Hi Jonathan,
You are heartily welcome.
I wonder - why do you consider using BGP to advertise the default route? Is there any problem with this router being a formal ASBR?
Best regards,
Peter
jonathan johnson Wed, 03/05/2014 - 15:43
Hi Peter,
I was hoping to summarize routes on this router which is why I wanted it not to be an ASBR.  Thinking about it more I don't think I will use BGP to inject a default route.  I might need have a think about the overall design.
Jonathan
Richard Burts Wed, 03/05/2014 - 19:46
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jonathan
In reading this thread it seems that you believe that a router can not/will not do summarization if it is an ASBR. Is that what you believe? If so then on what basis do you believe this?  It is my belief that as long as a router has at least one interface in area 0 and at least one interface in some other area (this is the basic definition of an ABR) that it can generate summaries of routes in one area to other areas. I am not aware of any restriction based on being an ASBR.
Rick
Peter Paluch Wed, 03/05/2014 - 21:56
  • Cisco Employee,
Hi Rick,
You are completely right, there are absolutely no restrictions (not even interactions that I would be aware of) for an ASBR to also act as an ABR and perform inter-area prefix summarization and filtering.
Best right,
Peter
jonathan johnson Sat, 03/08/2014 - 14:21
Thanks for your posts Peter and Richard.  It looks like I need to spend some time to revisit my understanding of OSPF areas and associated router functions.
Thanks again,
Jonathan
Richard Burts Mon, 03/24/2014 - 05:21
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Jonathan
Have you come to any resolution about this question?
Rick
