03-06-2014 12:03 AM - edited 03-07-2019 06:33 PM
Hi Team,
i have static RP for a group range (225.0.0.0 to 255.0.0.0) and i have configured dynamic RP (bootstrap mechanism) for the same group range.
which one will be elected as RP-SET.
please share your views.
thanks a lot in advance.
regards,
Rajesh kumar V
Solved! Go to Solution.
03-06-2014 05:49 AM
Rajesh
Static RP can co-exist with dynamic RP mechanisms (ie: Auto-RP). Dynamically learned RP takes precedence over manually configured RPs. If a router receives Auto-RP information for a multicast group that has manually configured RP information, then the Auto-RP information will be used.
Jon
03-06-2014 05:46 AM
Any suggestion very much appreciated.
03-06-2014 05:49 AM
Rajesh
Jon
03-06-2014 10:54 PM
thanks jon. now i got clarified. thanks agian.
