Warning message
Local user authentication fails
LDAP is configured in my UCS and default authentication is configured to ldap. But I always kept console authentication to local. Now I´m not able to login with the local user. Neither on the console nor on the GUI. I can log in with my ldap user in the console and can check that the console authentication is set to local. My ldap user has the role admin but I´m not permitted to change any settings regarding authentication.
SHOW AUTHENTICATION:
Console authentication: Local
Default authentication: Ldap
Role Policy For Remote Users: Assign Default Role
SHOW CONSOLE-AUTH:
    Realm                        Authentication server group
    Local
Any Ideas? What can I do?
Thanks....
jgeorge_dd Thu, 04/10/2014 - 21:55
Hey Adrian,
Did you fix this issue? I have the same problem too. If you have a a solution please share
Regards..Jibby
jgeorge_dd Fri, 04/11/2014 - 03:17
Thanks Guys, I created a authentication domain with relam local and login with admin used prefixing that domain and it worked.
