Warning message
Upgrading from 2.1(1a) to 2.1(3b)
Mar 6th, 2014
Hi All,
I would like to know if anybody has recently upgrade from the above mentioned version , I would like to know if you have found amy documents detailing the steps to carried out . Is it a smooth transition ? your input in invaluable .
Sincerely,
Saleem Roumaldaro.
Overall Rating: 5 (2 ratings)
Saleem Roumaldaro Thu, 03/06/2014 - 12:02
Hi David,
I will take a look at it, does autoinstall works well if i am upgrading from 2.1(1A) to 2.1(2a) ?
Saleem
David Alpizar Thu, 03/06/2014 - 12:07
  • Cisco Employee,
Saleem ,
Yes, the auto install option will be available for the 2.1 version.
Hope this answer your question.
-David
