03-06-2014 03:41 PM - edited 03-07-2019 06:34 PM
Hi All.
I've come up with this problem and i could see some people have had the same issue. I've tried to overlook and check other replies but it didn't help me. So I'm hoping someone could spot the problem. Here are the details:
2 x WS-C3750G-24T-E in stack
Cisco IOS Software, C3750 Software (C3750-ADVIPSERVICESK9-M), Version 12.2(46)SE, RELEASE SOFTWARE (fc2)
switch#sh sdm prefe
The current template is "desktop IPv4 and IPv6 routing" template.
The selected template optimizes the resources in
the switch to support this level of features for
8 routed interfaces and 1024 VLANs.
number of unicast mac addresses: 1.5K
number of IPv4 IGMP groups + multicast routes: 1K
number of IPv4 unicast routes: 2.75K
number of directly-connected IPv4 hosts: 1.5K
number of indirect IPv4 routes: 1.25K
number of IPv6 multicast groups: 1.125k
number of directly-connected IPv6 addresses: 1.5K
number of indirect IPv6 unicast routes: 1.25K
number of IPv4 policy based routing aces: 0.25K
number of IPv4/MAC qos aces: 0.5K
number of IPv4/MAC security aces: 0.5K
number of IPv6 policy based routing aces: 0.25K
number of IPv6 qos aces: 0.5K
number of IPv6 security aces: 0.5K
There are 2 ISPs, G1/0/1 and G2/0/1. After creating a route-map i can apply a policy route-map to Vlan5 and it accepts without any errors. But when you do sh run vlan5 the command is not there, it's not applied.
Any help will be appretiated.
Thanks.
03-06-2014 03:50 PM
Can you post the PBR config as it appears in your config ?
Jon
03-06-2014 04:00 PM
Sorry, also can you post the vlan 5 SVI configuration as well.
Jon
03-06-2014 04:36 PM
Might be a while before i logon again so -
1) if you have VRF or WCCP applied to vlan 5s SVI you cannot also use PBR
2) only IPv4 traffic can be policy routed even though you have the dual template
3) if you have deny statement in your route map then the policy will not be applied to the interface.
Jon
03-07-2014 01:57 AM
Hi Jon.
Thanks for your reply. I didn't put those configs as they're basic without use of VRF and WCCP. Also i've checked or tried to find the list of unsupported commands and didn't see them in that list. See config below with some extras:
track 11 rtr 1 reachability
track 22 rtr 2 reachability
ip routing
no ip dhcp use vrf connected
interface GigabitEthernet1/0/1
description ISP1
no switchport
ip address 9.9.9.2 255.255.255.252
no ip proxy-arp
no ip mroute-cache
speed 100
duplex full
ipv6 address 2B01:4B8:0:3::2/64
ipv6 ospf 1 area 0
no mdix auto
no cdp enable
interface GigabitEthernet2/0/1
description ISP2
no switchport
ip address 9.9.9.5 255.255.255.252
ip ospf cost 10000
speed 1000
duplex full
ipv6 address 2B01:4B8:0:7::2/64
ipv6 enable
ipv6 ospf cost 10000
ipv6 ospf 1 area 0
interface Vlan5
description Company Ext Subnet
ip address 9.9.8.1 255.255.255.128
no ip proxy-arp
no ip mroute-cache
ipv6 address 2B01:4B8:1:22::1/64
ipv6 ospf 1 area 15
access-list 111 permit tcp any any eq www
route-map pbr1 permit 10
match ip address 111
set interface GigabitEthernet2/0/1 GigabitEthernet1/0/1
route-map pbr1 permit 20
set interface GigabitEthernet1/0/1 GigabitEthernet2/0/1
route-map pbr2 permit 10
set ip next-hop verify-availability 9.9.9.6 1 track 11
set ip next-hop 9.9.9.1
route-map pbr2 permit 20
set ip next-hop verify-availability 9.9.9.1 1 track 22
set ip next-hop 9.9.9.6
I've tried to apply both policies pbr1 and pbr2, it allowed to do that without errors but at the end it wasn't there.
Cheers,
03-07-2014 09:28 AM
Couple of things -
1) from the config guide for your IOS -
Policy-based routing based on packet length, TOS, set interface, set default next hop, or set default interface are not supported. Policy maps with no valid set actions or with set action set to Don't Fragment are not supported.
So pbr1 isn't going to work
2) i'm not sure whether verify-availablity is supported.
so some things to try -
1) try using pbr2 but without the "verify-availability" and see if it shows in the running config
2) if 1) still doesn't work then try creating a dummy vlan and SVI with no ipv6 addressing and try applying pbr2 to it
Jon
03-10-2014 03:04 AM
Thanks guys.
Ashish, two requirements are already in place. Looks like unsupported commands.
Jon, that switch is in a company's live working enviroment, so i don't want to mess around too much in case something happened or need to restart it.
I saw that some commands are not supported, but "set ip next-hop" and "verify-availability" are not on that list. I'll try your suggestions probably after working hours.
Also, is there a point to upgrade IOS to the latest, i think its' 12.2(55). Will it include all commands, do you knoiw?
Cheers,
03-07-2014 11:04 AM
Hi segey,
Please check this blog ,it may help you
Ashish
