Cisco Aironet 1552 SA - EIRP
Answered Question
Mar 6th, 2014
Hi All
Currently, i have a cisco AIR 1552SA with Controller 5508
as datasheet of cisco AIR 1552SA :
+ 802.11b maximum transmit power - 28dbm with 2 antennas
+ three Cisco AIR-ANT2547V-N-HZ antennas dual-band, omnidirectional, stick antennas with 4dbi ( 2.4Ghz ) and 7 dbi ( 5Ghz )
If you set 802.11b, EIRP ( 2,4Ghz ) = 28dbm + 4 dbi = 32 dbm correct ?
i show advance 802.11b in wirless controller
=> just 802.11b is 15 dbm
now, i want to config WLC to set maximum transmit power to AIR 1552SA ( 32dbm )
pls help me
Correct Answer by Sandeep Choudhary about 3 years 5 months ago
HI Nguyen,
Here is my other AP with external antenna:
(WLAN1) >show ap config 802.11b AP035
    Tx Power
      Num Of Supported Power Levels ............. 7
      Tx Power Level 1 .......................... 17 dBm
      Tx Power Level 2 .......................... 14 dBm
      Tx Power Level 3 .......................... 11 dBm
      Tx Power Level 4 .......................... 8 dBm
      Tx Power Level 5 .......................... 5 dBm
--More-- or (q)uit
      Tx Power Level 6 .......................... 2 dBm
      Tx Power Level 7 .......................... -1 dBm
      Tx Power Configuration .................... AUTOMATIC
      Current Tx Power Level .................... 1
    Phy OFDM parameters
      Configuration ............................. AUTOMATIC
      Current Channel ........................... 1
      Extension Channel ......................... NONE
      Channel Width.............................. 20 Mhz
      Allowed Channel List....................... 1,2,3,4,5,6,7,8,9,10,11,12,
        ......................................... 13
      TI Threshold .............................. -50
      Legacy Tx Beamforming Configuration ....... CUSTOMIZED
      Legacy Tx Beamforming ..................... ENABLED
      Antenna Type............................... EXTERNAL_ANTENNA
      External Antenna Gain (in .5 dBi units).... 0
      Diversity.................................. DIVERSITY_ENABLED
      802.11n Antennas
         A....................................... ENABLED
         B....................................... ENABLED
         C....................................... ENABLED
         D....................................... ENABLED
So I think you have only 5 power level and the max power you can get is 15dBm for first  2 AP according to regulatery domain.
the 3rd AP which is connected with WLC can have 18 dBm but this all depends on your regulatery domain made APs.
Scott is right, if you need to have good signal the add more APs.
Dont forget to rate helpful posts
HI,
As per my exp, it is included with antnna gain.
Check my logs:
(WLAN1) >show advanced 802.11b tx
Leader Automatic Transmit Power Assignment
  Transmit Power Assignment Mode................. OFF
  Transmit Power Update Interval................. 600 seconds
  Transmit Power Threshold....................... -70 dBm
  Transmit Power Neighbor Count.................. 3 APs
  Min Transmit Power............................. -10 dBm
  Max Transmit Power............................. 30 dBm
  Transmit Power Update Contribution............. SNI..
  Transmit Power Assignment Leader............... GKCWLAN1 (10.24.80.1)
  Last Run....................................... 351 seconds ago
  TPC Mode....................................... Version 1
  TPCv2 Target RSSI.............................. -67 dBm
  TPCv2 VoWLAN Guide RSSI........................ -67.0 dBm
  TPCv2 SOP...................................... -85.0 dBm
  TPCv2 Default Client Ant Gain..................   0.0 dBi
  TPCv2 Path Loss Decay Factor...................   3.6
  TPCv2 Search Intensity......................... 10 Iterations
AP Name                          Channel    TxPower       Allowed Power Levels
--More-- or (q)uit
AP015                         *6         *1/7 (17 dBm) [17/14/11/8/5/2/-1/0]
AP014                         *1         *1/7 (17 dBm) [17/14/11/8/5/2/-1/0]
AP001                         *11        *1/7 (17 dBm) [17/14/11/8/5/2/-1/0]
AP005                         *6         *1/7 (17 dBm) [17/14/11/8/5/2/-1/0]
AP011                         *1         *1/7 (17 dBm) [17/14/11/8/5/2/-1/0]
AP002                         *1         *1/7 (17 dBm) [17/14/11/8/5/2/-1/0]
AP008                         *1         *1/7 (17 dBm) [17/14/11/8/5/2/-1/0]
AP020                         *11        *1/7 (17 dBm) [17/14/11/8/5/2/-1/0]
AP007                         *11        *1/7 (17 dBm) [17/14/11/8/5/2/-1/0]
AP013                         *11        *1/7 (17 dBm) [17/14/11/8/5/2/-1/0]
(WLAN1) >show ap config 802.11b AP015
Cisco AP Identifier.............................. 11
Cisco AP Name.................................... AP015
Country code..................................... xxxxxxxxxxxxxxxxxxxxxxx
Regulatory Domain allowed by Country............. 802.11bg:-E     802.11a:-E
AP Country code.................................. xxxxxxxxxxxxxxxxxxxxxxxxx
AP Regulatory Domain............................. -E
AP Model......................................... AIR-CAP2602I-E-K9
AP Image......................................... C2600-K9W8-M
IOS Version...................................... 15.2(2)JA1$
Reset Button..................................... Enabled
AP Serial Number................................. FCZ1729D2TF
AP Certificate Type.............................. Manufacture Installed
AP User Mode..................................... AUTOMATIC
AP User Name..................................... admin
AP Dot1x User Mode............................... Not Configured
AP Dot1x User Name............................... Not Configured
Cisco AP system logging host..................... 255.255.255.255
AP Up Time....................................... 75 days, 22 h 37 m 28 s
AP LWAPP Up Time................................. 75 days, 19 h 08 m 19 s
Join Date and Time............................... Sat Dec 21 15:30:47 2013
Join Taken Time.................................. 0 days, 00 h 00 m 21 s
    Tx Power
--More-- or (q)uit
    Phy OFDM parameters
      Current Channel ........................... 6
      Antenna Type............................... INTERNAL_ANTENNA
      Internal Antenna Gain (in .5 dBi units).... 8
      802.11n Antennas
Check max power per anteena gain:
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/channels/lwapp/reference/guide/lw_chp2/1300_chp.html
More info:
https://supportforums.cisco.com/docs/DOC-12954
Hi Nguyen,
Agree with scott, It depends on the regulatery domain.
Check about the cahnnels and Power level for specific domain:
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/channels/lwapp/reference/guide/lw_chp2/1240_chp.html#wp1044347
Overall Rating: 5 (3 ratings)
Scott Fella Thu, 03/06/2014 - 20:52
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
TX power depends in the country regulations. From the CLI, issue the following to determine the max TX power:
show advanced 802.11b txpower
ducnm1234 Thu, 03/06/2014 - 21:40
Hi Scoot
I am from VietNam.
When i show advanced 802.11b txpowe and result on AIR1552sa is 15dbm
This causes singal streng which is very week. I want to increse txpower
Scott Fella Fri, 03/07/2014 - 03:38
  • Hall of Fame,
    2017 Wireless
You can't increase power more than what the AP is manufactured for (regulatory domain). If you have weak signal, then you need to add more access points. Looking at your output, 15dbm is your max for that country and the 2.4ghz channel. The max tx power is set for the antenna that Cisco allows you to use. You want to increase EIRP past what the regulations is, then replace the antennas with a 3rd party that has a higher gain. This of course can get you in trouble if in your country they are strict with regulations. 15dbm is the tx power for your radio and not the total EIRP.
Correct Answer
Sandeep Choudhary Thu, 03/06/2014 - 23:16
  • Purple, 4500 points or more
    2017 Wireless
Hi Nguyen,
ducnm1234 Fri, 03/07/2014 - 00:29
AIR-CAP1552SA-E-K9
Log of show advance 802.11b Txpower
  Transmit Power Assignment Mode................. AUTO
  Update Contribution
    Noise........................................ Enable
    Interference................................. Enable
    Load......................................... Disable
    Device Aware................................. Disable
  Transmit Power Assignment Leader............... Cisco5500 (10.10.2.254)
  Last Run Time.................................. 0 seconds
--More-- or (q)uit
APdca5.f4b8.fa3c                 *6         *1/5 (15 dBm) [15/12/9/6/3/0/0/0]
APdca5.f4b8.f9fc                 *11        *1/5 (15 dBm) [15/12/9/6/3/0/0/0]
AP885a.9288.eac5                 *1         *1/6 (18 dBm) [18/15/12/9/6/3/3/3]
I not sure about Tx Power 15dbm with gain of angtena or not
thanks All
Correct Answer
Sandeep Choudhary Fri, 03/07/2014 - 01:54
    2017 Wireless
HI,
Check my logs:
--More-- or (q)uit
    Tx Power
--More-- or (q)uit
    Phy OFDM parameters
      802.11n Antennas
More info:
ducnm1234 Fri, 03/07/2014 - 03:33
Phy OFDM parameters
      Channel Assigned By ....................... DCA
      802.11n Antennas
Hi you
AP use  3 external antenna, each antenna has 4dbi, i see with regulatory domain E, max power is 15dbm
but not EIRP. Because when you plug antenna, signal strength increase more.
pls take a look highlight, i dont understand   External Antenna Gain (in .5 dBi units).... 0
Correct Answer
Sandeep Choudhary Fri, 03/07/2014 - 05:28
    2017 Wireless
HI Nguyen,
    Tx Power
--More-- or (q)uit
    Phy OFDM parameters
      802.11n Antennas
ducnm1234 Fri, 03/07/2014 - 06:09
=> this is AP indoor 3602I-E-K9 in my network
With the same E Regulatory domain why the indoor ap 3602 has power than 1552sa outdoor.
it's not simple that can explaint to customer about this.
Scott Fella Fri, 03/07/2014 - 08:19
  • Hall of Fame,
    2017 Wireless
It's regulations... indoor has its own regulations from outdoor depending on the country.  The antenna gain on the 3602i is also a lower gain antenna.
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Scott Fella Fri, 03/07/2014 - 08:35
  • Hall of Fame,
    2017 Wireless
Here is an excel spreadsheet for the 3600's channel and max power:
http://tinyurl.com/kbfskeg
Scott
Sandeep Choudhary Fri, 03/07/2014 - 08:39
    2017 Wireless
Hi Nguyen,
The maximum power setting will vary by channel and according to individual country regulations.
For this you cant do anything because cisco made this products and you can give the maual of these Access Point to your custmoer to make them understand.
http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1550-series/data_sheet_c78-711419.pdf
http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-3600-series/data_sheet_c78-686782.html
Regrads
