Warning message
WLANs creation, configuration, Cisco Prime Infrastructure
Answered Question
Mar 7th, 2014
Is it possible, to create WLANs on controllers using CPI 2.0,
I have discovered a 5508 WLC after imported all the templates, in "WLAN configuration" I just have the option to "Delete WLAN" and another options, but it doesn't show the option to "Add WLAN"
Thanks in advance,
Correct Answer by Scott Fella about 3 years 5 months ago
Have you tried to switch to classic theme and then try to add a new WLAN configuration?
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Overall Rating: 4.5 (2 ratings)
Correct Answer
Scott Fella Fri, 03/07/2014 - 04:52
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Scott
Sandeep Choudhary Fri, 03/07/2014 - 04:53
  • Purple, 4500 points or more
    2017 Wireless
Yes you can add WLAN in PI.
Create a Template:
screenshot:
Create wlan on controller:
Hope it helps.
Dont forget to rate helpful posts
