03-07-2014 09:11 AM - edited 03-07-2019 06:35 PM
I have a Cisco 2811 router and have configured it to be a DHCP server at a remote site. It seems like it should be pretty straight forward to configure DHCP. Apparently I'm missing something because I can't get clients to receive an address. Below are the applicable parts of the config. I also have tried associating the DHCP pool with the Claims vrf and that did not work either.
ip dhcp excluded-address 10.10.30.0 10.10.30.99
ip dhcp excluded-address 10.10.30.201 10.10.30.255
ip dhcp pool Claims_Office
network 10.10.30.0 255.255.255.0
domain-name fmi.com
default-router 10.10.30.253
dns-server 10.10.10.191
lease 7
interface FastEthernet0/0
description Claims Office
vrf forwarding Claims
ip address 10.10.30.253 255.255.255.0
duplex auto
speed auto
no mop enabled
interface FastEthernet0/0/0.1205
encapsulation dot1Q 1205
ip address 192.168.103.2 255.255.255.252
03-07-2014 05:09 PM
Nathan,
I think the issue is with your exclusions
This will exclude the full subnet
Can you try changing it to
no ip dhcp excluded-address 10.10.30.0 10.10.30.99
ip dhcp excluded-address 10.10.30.1 10.10.30.99
Then retry a dhcp test
See what the output from show ip dhcp pool looks like before and after the change
Alex.
Please rate useful posts.
03-10-2014 07:37 AM
Unfortunately that didn't work. Here is the output before:
Pool Claims_Office :
Utilization mark (high/low) : 100 / 0
Subnet size (first/next) : 0 / 0
Total addresses : 254
Leased addresses : 0
Pending event : none
1 subnet is currently in the pool :
Current index IP address range Leased addresses
10.10.30.1 10.10.30.1 - 10.10.30.254 0
And after:
What I want is for it to assign addresses from 10.10.30.100-199
