03-07-2014 01:57 PM - edited 03-07-2019 06:35 PM
I have a training class and the powers at be would like for me to plug a desktop d-link dumb switch into a port on the 3560 switch that we currently have onsite. Will it be as simple as turning down the port security on the port that is in use or would I have to trunk or uplink the port that will be used. New admin here...thanks.
03-07-2014 03:22 PM
Hard to tell. I'm not sure what model of D-Link (you'll need to do your own research) because not all "smart" switch can support VLANs other than VLAN 1 or multiple VLANs. It's not as "easy" because in some cases it could potentially cause a network loop.
Disable UDLD, BPDU Guard and STP portfast on the 3560 port facing the D-Link.
When you connect the switch, make sure you are personally there nearest the port. The very first sign of "slow network" unplug the switch immediately from the D-Link.
03-08-2014 09:33 AM
I don't think you can trunk a dumb switch. So, if you have only one vlan on the 3560, than you can just plug it in, turn down port security and should be fine.
