03-09-2014 12:25 AM - edited 03-07-2019 06:36 PM
I am in the process of configuring a router and while deploying some of the NAT translations I ran into a problem.
router(config)#ip nat inside source static tcp 10.0.20.105 22 interface gigabitEthernet 1/1 23
%Port 23 is being used by system
router(config)#do clear ip nat trans forced
Telnet is not enabled, and clearing the nat translations did not fix the problem. Anyone have any ideas?
Thanks!
03-10-2014 05:37 PM
Bump.... this was opened during Cisco's maintenance window.
05-16-2014 12:24 PM
I have the same issue on 6504-E with IOS version s72033-adventerprisek9-mz.151-2.SY2.bin.
you fixed the problem?
Sergio
