03-09-2014 11:06 PM - edited 03-10-2019 09:30 PM
Hi all
Why do we need the " aaa authentication enable default group tacacs+ enable" . Is " aaa authentication login default group tacacs+ enable"
is not enough ?
Solved! Go to Solution.
03-09-2014 11:58 PM
aaa authentication login default group tacacs+ enable > This command is required for the login authentication when you very first time get prompt to enter username/password defined on the tacacs server.
username: tacacs username
Password: tacacs password
aaa authentication enable default group tacacs+ enable > This command is required for the enable authentication when you need to enter the enable password defined on the tacacs server.
> enable
password: tacacs enable password
In both the commands you've defined enable keyword in the last as a fallback method. In case tacacs goes down you'll be able to authenticate with the locally defined enable password.
The only thing that you can replace in the first command is enable with the local as a fallback method.
aaa authentication login default group tacacs+ local
Note: Plz ensure that you have a local username/password created with privilege 15 and enable secret password.
Jatin Katyal
**Do rate helpful posts**
03-09-2014 11:58 PM
> enable
Jatin Katyal
03-10-2014 03:09 AM
Jatin has correctly explained and kindly check the link for aaa command explanination
http://www.cisco.com/c/en/us/td/docs/security/asa/asa72/command/reference/cmd_ref/a1_72.html
03-10-2014 04:41 AM
"aaa authentication login default group tacacs+ enable" ensure that whenever any user try to access any device he should get login prompt to authenticate its user credential via TACACS server or if server is down then enable password is used for user authentication, as Jatin suggested use local as a fallback instead of enable.
But with this command only user credentials are validated and user even if he have a privilege level of 15, will get privilege level 1. If enable password for level 15 is not locally configured on router, user can not go in to enable mode.
aaa authentication enable default group tacacs+ enable is used to determine if a user can access the privileged command level.
If you also want your users to authenticate through TAC+ in order to get into enable mode, make sure your console port session is still active and add this command to the router:
!--- For enable mode, list 'default' looks to TAC+ !--- then enable password if TAC+ does not run. aaa authentication enable default tacacs+ enable
03-10-2014 11:35 PM
Hi jatin ,
Just for clariffication , if i add " aaa authentication enable default group tacacs+ enable" , once authenticated device will go directly to enable mode .
in case tacacs failed user has to enter local username and password . once it is authenticated
" aaa authentication enable default group tacacs+ enable " will be executed and the user have to enter the enable (local db ) secret .
Please correct me if iam wrong
aaa authorization console
aaa authorization exec default group tacacs+ if-authenticated
aaa authorization commands 15 default group tacacs+ if-authenticated
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting connection default start-stop group tacacs+
03-11-2014 01:53 AM
In order to land directly to enable mode (#), you don't need the below listed command.
We need the above command when you want to go on enable mode after entering the enable password.
Instead use this only and push shell profile privilege level 15 from the tacacs server. That would allow you to land directly on the enable mode.
aaa authorization exec default group tacacs+ local
User only need to enter the enable password only in absence of the above command.
Jatin Katyal
**Do rate helpful posts **
03-12-2014 11:03 PM
Supportsib,
Did that answer your question or you need more clarification?
~BR
Jatin Katyal
03-23-2014 07:53 AM
Hi Jatin
Thank you for your help.
Kindly explain what is " aaa authentication enable default group tacacs+ enable".
Kindly explain in what situtation i would use the above statement
03-23-2014 01:45 PM
Here we are saying that for enable mode (enable password) we want to use the default group tacacs+. Doing this it first tries to contact a TACACS+ server. If no server can be found, AAA tries to use the enable password created locally on the device (switch). If there will be no enable password configured, you'll see an error "password required but none set".
We should use this command if we want the end user to enter enable password before he gets access to exec mode. This is actually add another security check for the user. In case your tacacs is down so you should have some back dorr entry and that's a reason we have ENABLE as a keyword at the last of the command.
Hope this helps.
Jatin Katyal
