ACE does not suport NTLM authentication and only supports basic authentication. You can use TCL scripting for probe but i personally haven't used one and couldn't find any example either.
Thanks for the reply, I will try the TCL option. But do you know if Cisco plan to support NTLM built in the HTTP probe in future releases? After all, the ACE's end of SW maintenance releases date is 24/01/15.
Thanks.
