Warning message
I am running call manager 8.0.3.20000-2 on a MCS 7825 I4 can any advise on the upgrade path please?
Mar 11th, 2014
Overall Rating: 4 (2 ratings)
Antonio Knox Tue, 03/11/2014 - 08:40
  • Silver, 250 points or more
The 7825 I4 should be able to run 9.x {via upgrade to 8.6 then 9.x) , if you have adequate memory and drive space, upgrades may be necessary as I'm not certain if hardware specs you're working with. You can check your model on the compatibility matrix here. http://www.cisco.com/c/en/us/products/collateral/unified-communications/... Also, check out the release notes for Cucm 9.x (or 8.6 if that's your target release), I'd post the link but I'm typing this on my phone with bad signal. Please rate of helpful.
