3600 AP keeps bouncing between Primary & Secondary 5760 WLC
Mar 11th, 2014
Hello All,
I am not sure if it was a good idea to change the controllers from software based to IOS based :(..... Anyway this is the first time I am working on the IOS based controllers and have been going through very unusual thing. I have a 3600 AP and a couple of 2600 AP, I am just at the start of the configuration for a new deployment. Even though I have many concerns but I will start with the one which is bothering me the most, which is the APs keep jumping from a primary controller to the secondary controller. I have attached the sh run, sh logging, and the sh version for a 3600 AP and the two controllers. All I can understand from the logs is that the capwap interface keeps going down which causes the AP to fall back to the other controller, I have also tried turning off the AP FALLBACK feature, still no luck.
Addiditional Confusions,
Does any one know as how to setup HA in these controllers, as I do not see any HA or RP (Port) on these controllers neither there is any stacking module on the controllers. Would it be the old way of doing it, which was defining Primary and Secondary Controllers on the APs, if yes than I should receive two different licenses for the Controllers. But these are my devices Part numbers:
Primary: AIR-CT5760-500-K9
Secondary: AIR-CT5760-HA-K9
for now I have enabled the evaluation license on both the devices. I hope that does not make any difference.
Owais Khan Wed, 03/12/2014 - 09:08
I have been doing some of my own trouble shooting and found out that as soon as I create a layer 3 interface on the controller so as to map it to any SSID, all of my APs start to jump on to the secondary controller and since there is a primary and secondary controller configuration on each AP they tend to come back but than soon after they jump back to the secondary....... As soon as I delete the additional layer 3 interfaces, apart from the wireless management, I get all the APs back to normal register to the controller without a glitch, I am pasting the logs being received for the APs behaviour. I have marked the logs in between with Asterics to indicate when I cleared the layer 3 interfaces and from there onwards all the APs started coming up again
Mar 12 15:09:58.624: *%LOG-3-Q_IND: 1 wcm:  Invalid AP event (CAPWAP Discovery Request) and state (CAPWAP Join Response) combination[...It occurred 4 times.!]
Mar 12 15:09:58.624: *%CAPWAP-3-ECHO_ERR: 1 wcm:  Did not receive heartbeat reply; AP: 1c1d.86ee.7b40
Mar 12 15:10:03.427: *%CAPWAP-3-INVALID_STATE_EVENT: 1 wcm:  Invalid AP event (CAPWAP Discovery Request) and state (CAPWAP Join Response) combination
Mar 12 15:10:05.373: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap13, changed state to down
Mar 12 15:10:08.539: *%CAPWAP-3-INVALID_STATE_EVENT: 1 wcm:  Invalid AP event (CAPWAP Discovery Request) and state (CAPWAP Join Response) combination[...It occurred 7 times/sec!.]
Mar 12 15:10:11.657: *%LOG-3-Q_IND: 1 wcm:  Invalid AP event (CAPWAP Discovery Request) and state (CAPWAP Join Response) combination[...It occurred 3 times.!]
Mar 12 15:10:11.657: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  34:db:fd:67:1f:e0
Mar 12 15:10:11.660: %LINK-3-UPDOWN: Interface Capwap30, changed state to up
Mar 12 15:10:12.703: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap30, changed state to up
Mar 12 15:10:13.111: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap16, changed state to down
Mar 12 15:10:13.678: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap28, changed state to down
Mar 12 15:10:15.840: *%LOG-3-Q_IND: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  34:db:fd:67:1f:e0
Mar 12 15:10:15.840: *%CAPWAP-3-INVALID_STATE_EVENT: 1 wcm:  Invalid AP event (CAPWAP Discovery Request) and state (CAPWAP Join Response) combination
Mar 12 15:10:18.070: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap11, changed state to down
Mar 12 15:10:18.268: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap20, changed state to down
Mar 12 15:10:20.695: *%CAPWAP-3-INVALID_STATE_EVENT: 1 wcm:  Invalid AP event (CAPWAP Discovery Request) and state (CAPWAP Join Response) combination[...It occurred 4 times/sec!.]
Mar 12 15:10:25.608: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap14, changed state to down
Mar 12 15:10:32.273: *%CAPWAP-3-INVALID_STATE_EVENT: 1 wcm:  Invalid AP event (CAPWAP Discovery Request) and state (CAPWAP Join Response) combination[...It occurred 3 times/sec!.]
Mar 12 15:10:35.526: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap24, changed state to down
Mar 12 15:10:47.032: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap29, changed state to down
Mar 12 15:10:50.913: *%CAPWAP-3-INVALID_STATE_EVENT: 1 wcm:  Invalid AP event (CAPWAP Discovery Request) and state (CAPWAP Join Response) combination[...It occurred 2 times/sec!.]
Mar 12 15:10:58.725: *%LOG-3-Q_IND: 1 wcm:  Invalid AP event (CAPWAP Discovery Request) and state (CAPWAP Join Response) combination[...It occurred 3 times.!]
Mar 12 15:10:58.726: *%CAPWAP-3-INVALID_STATE_EVENT: 1 wcm:  Invalid AP event (CAPWAP Configuration Update Request) and state (CAPWAP Join Response) combination
Mar 12 15:10:58.726: *%LOG-3-Q_IND: 1 wcm:  Invalid AP event (CAPWAP Configuration Update Request) and state (CAPWAP Join Response) combination
Mar 12 15:10:58.726: *%CAPWAP-3-INVALID_STATE_EVENT: 1 wcm:  Invalid AP event (CAPWAP Discovery Request) and state (CAPWAP Join Response) combination
Mar 12 15:11:00.521: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap30, changed state to down
Mar 12 15:11:08.450: *%LOG-3-Q_IND: 1 wcm:  Invalid AP event (CAPWAP Discovery Request) and state (CAPWAP Join Response) combination[...It occurred 3 times.!]
Mar 12 15:11:08.450: *%CAPWAP-3-INVALID_STATE_EVENT: 1 wcm:  Invalid AP event (CAPWAP Configuration Update Request) and state (CAPWAP Join Response) combination
Mar 12 15:11:08.921: *%CAPWAP-3-INVALID_STATE_EVENT: 1 wcm:  Invalid AP event (CAPWAP Join Request) and state (CAPWAP Join Response) combination
Mar 12 15:11:09.318: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  f0:29:29:92:c7:f0
Mar 12 15:11:09.319: %LINK-3-UPDOWN: Interface Capwap15, changed state to up
Mar 12 15:11:10.319: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap15, changed state to up
Mar 12 15:11:13.413: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap27, changed state to down
Mar 12 15:11:14.095: *%LOG-3-Q_IND: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  f0:29:29:92:c7:f0
Mar 12 15:11:14.095: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:b8:c0:a0
Mar 12 15:11:14.098: %LINK-3-UPDOWN: Interface Capwap23, changed state to up
Mar 12 15:11:15.098: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap23, changed state to up
VIP_G_M_Core1(config-if)#
Mar 12 15:11:56.713: *%LOG-3-Q_IND: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:b8:c0:a0
Mar 12 15:11:56.713: *%CAPWAP-3-INVALID_STATE_EVENT: 1 wcm:  Invalid AP event (CAPWAP Discovery Request) and state (CAPWAP Join Response) combination
Mar 12 15:12:06.178: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap23, changed state to down
Mar 12 15:12:06.899: *%CAPWAP-3-INVALID_STATE_EVENT: 1 wcm:  Invalid AP event (CAPWAP Discovery Request) and state (CAPWAP Join Response) combination[...It occurred 5 times/sec!.]
Mar 12 15:12:10.411: *%LOG-3-Q_IND: 1 wcm:  Invalid AP event (CAPWAP Discovery Request) and state (CAPWAP Join Response) combination[...It occurred 3 times.!]
Mar 12 15:12:10.411: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:cc:ca:60
Mar 12 15:12:10.413: %LINK-3-UPDOWN: Interface Capwap1, changed state to up
Mar 12 15:12:11.266: *%LOG-3-Q_IND: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:cc:ca:60
Mar 12 15:12:11.266: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  1c:1d:86:ee:7b:40
Mar 12 15:12:11.267: %LINK-3-UPDOWN: Interface Capwap3, changed state to up
Mar 12 15:12:11.413: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap1, changed state to up
Mar 12 15:12:12.267: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap3, changed state to up
Mar 12 15:12:16.889: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap4, changed state to down
Mar 12 15:12:30.365: *%LOG-3-Q_IND: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  1c:1d:86:ee:7b:40
Mar 12 15:12:30.365: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:b4:e6:10
Mar 12 15:12:30.366: %LINK-3-UPDOWN: Interface Capwap22, changed state to up
Mar 12 15:12:31.366: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap22, changed state to up
Mar 12 15:12:33.942: *%LOG-3-Q_IND: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:b4:e6:10
Mar 12 15:12:33.942: *%CAPWAP-3-INVALID_STATE_EVENT: 1 wcm:  Invalid AP event (CAPWAP Discovery Request) and state (CAPWAP Join Response) combination
Mar 12 15:12:48.627: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap1, changed state to down
Mar 12 15:12:51.385: *%CAPWAP-3-INVALID_STATE_EVENT: 1 wcm:  Invalid AP event (CAPWAP Discovery Request) and state (CAPWAP Join Response) combination[...It occurred 4 times/sec!.]
Mar 12 15:13:06.083: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap15, changed state to down
Mar 12 15:13:09.053: *%LOG-3-Q_IND: 1 wcm:  Invalid AP event (CAPWAP Discovery Request) and state (CAPWAP Join Response) combination[...It occurred 3 times.!]
Mar 12 15:13:09.053: *%CAPWAP-3-INVALID_STATE_EVENT: 1 wcm:  Invalid AP event (CAPWAP Configuration Update Request) and state (CAPWAP Join Response) combination
Mar 12 15:13:12.177: *%CAPWAP-3-INVALID_STATE_EVENT: 1 wcm:  Invalid AP event (CAPWAP Discovery Request) and state (CAPWAP Join Response) combination
Mar 12 15:13:16.687: *%LOG-3-Q_IND: 1 wcm:  Invalid AP event (CAPWAP Discovery Request) and state (CAPWAP Join Response) combination[...It occurred 2 times.!]
Mar 12 15:13:16.687: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  34:db:fd:67:1f:e0
Mar 12 15:13:16.688: %LINK-3-UPDOWN: Interface Capwap31, changed state to up
Mar 12 15:13:17.689: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap31, changed state to up
Mar 12 15:13:20.998: *%LOG-3-Q_IND: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  34:db:fd:67:1f:e0
Mar 12 15:13:20.998: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  34:db:fd:67:1d:c0
Mar 12 15:13:21.001: %LINK-3-UPDOWN: Interface Capwap21, changed state to up
Mar 12 15:13:22.001: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap21, changed state to up
Mar 12 15:13:23.935: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap22, changed state to down
Mar 12 15:13:40.943: *%LOG-3-Q_IND: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  34:db:fd:67:1d:c0
Mar 12 15:13:40.943: *%CAPWAP-3-INVALID_STATE_EVENT: 1 wcm:  Invalid AP event (CAPWAP Discovery Request) and state (CAPWAP Join Response) combination
Mar 12 15:13:41.815: %DOT1X-5-FAIL: Authentication failed for client (c0f8.da9f.8227) on Interface Ca21 AuditSessionID 0a06906e53207995000001b8
Mar 12 15:13:41.815: %AUTHMGR-5-FAIL: Authorization failed or unapplied for client (c0f8.da9f.8227) on Interface Ca21 AuditSessionID 0a06906e53207995000001b8
Mar 12 15:13:44.342: *%LOG-3-Q_IND: 1 wcm:  Invalid AP event (CAPWAP Discovery Request) and state (CAPWAP Join Response) combination[...It occurred 3 times.!]
Mar 12 15:13:44.342: *%CAPWAP-3-INVALID_STATE_EVENT: 1 wcm:  Invalid AP event (CAPWAP Configuration Update Request) and state (CAPWAP Join Response) combination
Mar 12 15:13:44.344: *%CAPWAP-3-INVALID_STATE_EVENT: 1 wcm:  Invalid AP event (CAPWAP Discovery Request) and state (CAPWAP Join Response) combination
Mar 12 15:13:54.081: *%LOG-3-Q_IND: 1 wcm:  Invalid AP event (CAPWAP Discovery Request) and state (CAPWAP Join Response) combination[...It occurred 2 times.!]
Mar 12 15:13:54.081: *%CAPWAP-3-INVALID_STATE_EVENT: 1 wcm:  Invalid AP event (CAPWAP Configuration Update Request) and state (CAPWAP Join Response) combination
Mar 12 15:13:55.673: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap31, changed state to down
Mar 12 15:13:57.761: *%LOG-3-Q_IND: 1 wcm:  Invalid AP event (CAPWAP Configuration Update Request) and state (CAPWAP Join Response) combination
Mar 12 15:13:57.761: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:cd:01:f0
Mar 12 15:13:57.763: %LINK-3-UPDOWN: Interface Capwap6, changed state to up
Mar 12 15:13:58.642: *%LOG-3-Q_IND: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:cd:01:f0
Mar 12 15:13:58.642: *%CAPWAP-3-ECHO_ERR: 1 wcm:  Did not receive heartbeat reply; AP: 1c1d.86ee.7b40
Mar 12 15:13:58.763: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap6, changed state to up
Mar 12 15:13:59.044: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap18, changed state to down
Mar 12 15:13:59.512: *%CAPWAP-3-INVALID_STATE_EVENT: 1 wcm:  Invalid AP event (CAPWAP Discovery Request) and state (CAPWAP Join Response) combination
Mar 12 15:14:07.361: *%LOG-3-Q_IND: 1 wcm:  Invalid AP event (CAPWAP Discovery Request) and state (CAPWAP Join Response) combination[...It occurred 2 times.!]
Mar 12 15:14:07.361: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:a1:6f:80
Mar 12 15:14:07.362: %LINK-3-UPDOWN: Interface Capwap2, changed state to up
Mar 12 15:14:08.111: *%LOG-3-Q_IND: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:a1:6f:80
Mar 12 15:14:08.111: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:a1:2d:60
Mar 12 15:14:08.115: %LINK-3-UPDOWN: Interface Capwap8, changed state to up
Mar 12 15:14:08.363: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap2, changed state to up
Mar 12 15:14:08.964: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap21, changed state to down
Mar 12 15:14:09.114: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap8, changed state to up
Mar 12 15:14:13.525: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap3, changed state to down
Mar 12 15:14:16.013: %RADIUS-4-RADIUS_DEAD: RADIUS server 10.6.5.132:1812,1813 is not responding.
Mar 12 15:14:16.013: %RADIUS-4-RADIUS_ALIVE: RADIUS server 10.6.5.132:1812,1813 is being marked alive.
THIS IS WHERE I DELETED THE LAYER 3 INTERFACES ON THE WLC
Mar 12 15:14:24.129: %DOT1X-5-FAIL: Authentication failed for client (c0f8.da9f.8227) on Interface Ca6 AuditSessionID 0a06906e532079bf000001b9
Mar 12 15:14:24.129: %AUTHMGR-5-FAIL: Authorization failed or unapplied for client (c0f8.da9f.8227) on Interface Ca6 AuditSessionID 0a06906e532079bf000001b9
Mar 12 15:14:42.537: *%LOG-3-Q_IND: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:a1:2d:60
Mar 12 15:14:42.537: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  dc:a5:f4:4d:80:10
Mar 12 15:14:42.539: %LINK-3-UPDOWN: Interface Capwap17, changed state to up
Mar 12 15:14:43.539: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap17, changed state to up
Mar 12 15:14:46.456: *%LOG-3-Q_IND: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  dc:a5:f4:4d:80:10
Mar 12 15:14:46.456: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  34:db:fd:67:22:a0
Mar 12 15:14:46.458: %LINK-3-UPDOWN: Interface Capwap5, changed state to up
Mar 12 15:14:47.459: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap5, changed state to up
Mar 12 15:14:52.018: *%LOG-3-Q_IND: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  34:db:fd:67:22:a0
Mar 12 15:14:52.018: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  dc:a5:f4:61:bc:d0
Mar 12 15:14:52.021: %LINK-3-UPDOWN: Interface Capwap0, changed state to up
Mar 12 15:14:53.021: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap0, changed state to up
Mar 12 15:14:58.080: *%LOG-3-Q_IND: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  dc:a5:f4:61:bc:d0
Mar 12 15:14:58.080: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  7c:95:f3:54:0d:d0
Mar 12 15:14:58.083: %LINK-3-UPDOWN: Interface Capwap9, changed state to up
Mar 12 15:14:59.082: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap9, changed state to up
Mar 12 15:14:59.727: *%LOG-3-Q_IND: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  7c:95:f3:54:0d:d0
Mar 12 15:14:59.727: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:cc:ca:60
Mar 12 15:14:59.730: %LINK-3-UPDOWN: Interface Capwap10, changed state to up
Mar 12 15:15:00.730: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap10, changed state to up
Mar 12 15:15:04.498: %SW_MATM-4-WIRELESS_MAC_MOVE_NOTIF: Host 40f0.2f58.a172 moving from Port Te1/0/1 to Port Ca17 as wireless entry
Mar 12 15:15:05.916: *%LOG-3-Q_IND: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:cc:ca:60
Mar 12 15:15:05.916: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  24:b6:57:5b:7d:90
Mar 12 15:15:05.918: %LINK-3-UPDOWN: Interface Capwap7, changed state to up
Mar 12 15:15:06.918: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap7, changed state to up
Mar 12 15:15:11.247: *%LOG-3-Q_IND: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  24:b6:57:5b:7d:90
Mar 12 15:15:11.247: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:b4:de:b0
Mar 12 15:15:11.248: %LINK-3-UPDOWN: Interface Capwap19, changed state to up
Mar 12 15:15:12.249: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap19, changed state to up
Mar 12 15:15:17.150: *%LOG-3-Q_IND: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:b4:de:b0
Mar 12 15:15:17.151: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  f0:29:29:92:c7:f0
Mar 12 15:15:17.152: %LINK-3-UPDOWN: Interface Capwap26, changed state to up
Mar 12 15:15:18.152: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap26, changed state to up
Mar 12 15:15:19.211: *%LOG-3-Q_IND: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  f0:29:29:92:c7:f0
Mar 12 15:15:19.211: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:b4:dd:60
Mar 12 15:15:19.212: %LINK-3-UPDOWN: Interface Capwap25, changed state to up
Mar 12 15:15:20.212: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap25, changed state to up
Mar 12 15:15:28.681: *%LOG-3-Q_IND: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:b4:dd:60
Mar 12 15:15:28.681: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:b8:ff:d0
Mar 12 15:15:28.684: %LINK-3-UPDOWN: Interface Capwap12, changed state to up
Mar 12 15:15:29.684: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap12, changed state to up
Mar 12 15:15:30.285: %SW_MATM-4-WIRELESS_MAC_MOVE_NOTIF: Host 286a.bae3.de95 moving from Port Te1/0/1 to Port Ca7 as wireless entry
Mar 12 15:15:31.078: %SW_MATM-4-WIRELESS_MAC_MOVE_NOTIF: Host e0b9.ba1e.02b4 moving from Port Te1/0/1 to Port Ca7 as wireless entry
Mar 12 15:15:34.781: *%LOG-3-Q_IND: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:b8:ff:d0
Mar 12 15:15:34.781: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:cc:a7:10
Mar 12 15:15:34.782: %LINK-3-UPDOWN: Interface Capwap13, changed state to up
Mar 12 15:15:35.783: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap13, changed state to up
Mar 12 15:15:37.962: *%LOG-3-Q_IND: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:cc:a7:10
Mar 12 15:15:37.962: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:b4:e6:10
Mar 12 15:15:37.964: %LINK-3-UPDOWN: Interface Capwap16, changed state to up
Mar 12 15:15:38.965: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap16, changed state to up
Mar 12 15:15:40.401: %SW_MATM-4-WIRELESS_MAC_MOVE_NOTIF: Host e0b9.ba1e.4c97 moving from Port Te1/0/1 to Port Ca7 as wireless entry
Mar 12 15:15:44.895: %AUTHMGR-4-UNAUTH_MOVE: (slow) MAC address (40f0.2f58.a172) from Ca0 to Ca17
Mar 12 15:15:50.124: *%LOG-3-Q_IND: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:b4:e6:10
Mar 12 15:15:50.124: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:b8:9b:20
Mar 12 15:15:50.127: %LINK-3-UPDOWN: Interface Capwap28, changed state to up
Mar 12 15:15:51.126: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap28, changed state to up
Mar 12 15:15:54.510: *%LOG-3-Q_IND: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:b8:9b:20
Mar 12 15:15:54.510: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  34:db:fd:a4:2f:00
Mar 12 15:15:54.512: %LINK-3-UPDOWN: Interface Capwap11, changed state to up
Mar 12 15:15:55.513: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap11, changed state to up
Mar 12 15:15:58.371: *%LOG-3-Q_IND: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  34:db:fd:a4:2f:00
Mar 12 15:15:58.371: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  dc:a5:f4:61:c9:10
Mar 12 15:15:58.374: %LINK-3-UPDOWN: Interface Capwap20, changed state to up
Mar 12 15:15:59.263: *%LOG-3-Q_IND: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  dc:a5:f4:61:c9:10
Mar 12 15:15:59.263: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:b4:ce:70
Mar 12 15:15:59.266: %LINK-3-UPDOWN: Interface Capwap14, changed state to up
Mar 12 15:15:59.373: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap20, changed state to up
Mar 12 15:16:00.265: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap14, changed state to up
Mar 12 15:16:02.655: *%LOG-3-Q_IND: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:b4:ce:70
Mar 12 15:16:02.655: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:b4:e7:10
Mar 12 15:16:02.658: %LINK-3-UPDOWN: Interface Capwap24, changed state to up
Mar 12 15:16:02.877: *%LOG-3-Q_IND: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:b4:e7:10
Mar 12 15:16:02.877: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  dc:a5:f4:4d:7f:a0
Mar 12 15:16:02.878: %LINK-3-UPDOWN: Interface Capwap29, changed state to up
Mar 12 15:16:03.659: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap24, changed state to up
Mar 12 15:16:03.879: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap29, changed state to up
Mar 12 15:16:07.595: *%LOG-3-Q_IND: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  dc:a5:f4:4d:7f:a0
Mar 12 15:16:07.595: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  34:db:fd:67:1f:e0
Mar 12 15:16:07.598: %LINK-3-UPDOWN: Interface Capwap30, changed state to up
Mar 12 15:16:08.597: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap30, changed state to up
Mar 12 15:16:10.146: *%LOG-3-Q_IND: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  34:db:fd:67:1f:e0
Mar 12 15:16:10.147: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:cc:d6:30
Mar 12 15:16:10.148: %LINK-3-UPDOWN: Interface Capwap27, changed state to up
Mar 12 15:16:10.821: *%LOG-3-Q_IND: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:cc:d6:30
Mar 12 15:16:10.821: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  1c:1d:86:ee:7b:40
Mar 12 15:16:10.824: %LINK-3-UPDOWN: Interface Capwap23, changed state to up
Mar 12 15:16:11.148: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap27, changed state to up
Mar 12 15:16:11.824: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap23, changed state to up
Mar 12 15:16:16.727: *%LOG-3-Q_IND: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  1c:1d:86:ee:7b:40
Mar 12 15:16:16.727: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:a1:62:e0
Mar 12 15:16:16.730: %LINK-3-UPDOWN: Interface Capwap4, changed state to up
Mar 12 15:16:17.729: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap4, changed state to up
Mar 12 15:16:21.617: *%LOG-3-Q_IND: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:a1:62:e0
Mar 12 15:16:21.617: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  dc:a5:f4:61:bf:50
Mar 12 15:16:21.618: %LINK-3-UPDOWN: Interface Capwap1, changed state to up
Mar 12 15:16:22.619: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap1, changed state to up
Mar 12 15:16:23.266: *%LOG-3-Q_IND: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  dc:a5:f4:61:bf:50
Mar 12 15:16:23.266: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:b8:c0:a0
Mar 12 15:16:23.268: %LINK-3-UPDOWN: Interface Capwap15, changed state to up
Mar 12 15:16:24.268: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap15, changed state to up
Mar 12 15:16:26.127: *%LOG-3-Q_IND: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:b8:c0:a0
Mar 12 15:16:26.127: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  34:db:fd:67:1d:c0
Mar 12 15:16:26.128: %LINK-3-UPDOWN: Interface Capwap22, changed state to up
Mar 12 15:16:27.128: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap22, changed state to up
Mar 12 15:16:27.919: *%LOG-3-Q_IND: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  34:db:fd:67:1d:c0
Mar 12 15:16:27.920: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:b8:a7:e0
Mar 12 15:16:27.921: %LINK-3-UPDOWN: Interface Capwap31, changed state to up
Mar 12 15:16:28.922: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap31, changed state to up
Mar 12 15:16:30.051: *%LOG-3-Q_IND: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:b8:a7:e0
Mar 12 15:16:30.051: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  34:db:fd:a4:29:00
Mar 12 15:16:30.053: %LINK-3-UPDOWN: Interface Capwap18, changed state to up
Mar 12 15:16:31.054: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap18, changed state to up
Mar 12 15:16:32.695: *%LOG-3-Q_IND: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  34:db:fd:a4:29:00
Mar 12 15:16:32.695: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:a1:67:40
Mar 12 15:16:32.697: %LINK-3-UPDOWN: Interface Capwap21, changed state to up
Mar 12 15:16:33.697: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap21, changed state to up
Mar 12 15:16:34.336: *%LOG-3-Q_IND: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:a1:67:40
Mar 12 15:16:34.336: *%LWAPP-3-VALIDATE_ERR: 1 wcm:  Validation of SPAM Vendor Specific Payload failed - AP  d0:c7:89:b4:d0:20
Mar 12 15:16:34.339: %LINK-3-UPDOWN: Interface Capwap3, changed state to up
Mar 12 15:16:35.339: %LINEPROTO-5-UPDOWN: Line protocol on Interface Capwap3, changed state to up
Kitri Waterman Wed, 03/12/2014 - 17:00
owaisakhan,
Do you have the option to *not* use IOS and go back to AireOS? I realize Cisco is pushing us away from AireOS, but my experience so far has been that AireOS has the most support and dev cycles right now.
I realize this doesn't directly answer your question.
