Warning message
Unable to find phone type in CUCM for manual registration
Answered Question
Mar 12th, 2014
We are using CUCM 8.0.3 , unable to find Phone type Cisco 8831 for manual registration. How can I add this phone type to CUCM ? Any help is appreciated.
Correct Answer by Rob Huffman about 3 years 5 months ago
Hi there,
+5 to my friends Mahmood & Nadeem here for their good ideas.
The problem here is that there is no Device Pack for CUCM 8.0.3 that supports the 8831 :( The ReadMe below is for the last/latest 8.0.3 device pack;
http://www.cisco.com/web/software/282074299/92918/cmterm-devicepack-8_0_...
You would need to upgrade CUCM to a minimum of 8.5.1 and then install ;
Cisco Unified Communications Manager 8.5(1.17118-1) Device Package - Compatible UCM Version: 8.5
cmterm-devicepack8.5.1.17121-1.cop.sgn
Cheers!
Rob
Correct Answer by Nadeem Ahmed about 3 years 5 months ago
have you added the device pack .If no please upload it in CUCM and then update
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/compat/devpack_c...
Further :you can also refer the IP phone feature and CUCM device pack compatibility matrix.
Br,
Nadeem Ahmed
Overall Rating: 5 (5 ratings)
mahmoodmkl Wed, 03/12/2014 - 23:55
  • Gold, 750 points or more
It seems you need to add the device support package.
Correct Answer
Rob Huffman Thu, 03/13/2014 - 06:21
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi there,
Cheers!
Rob
