Warning message
dns rewrite
Mar 13th, 2014
I'm not sure this is the best location for this question but I didn't find a better one.
One of our customers want to be able to use VPN to the local firewall from their guest network, if they connect with the vpn client to the ip address of the guestnetwork interface it's not a problem so I know that part works. They also have the requirement that you should do it with the same dns record from the outside as well as the inside (guest network in this case). So this is the current setup
Ip of outside interface on FW is 4.4.4.4 which is translated to vpn.cust.com
Ip of guest interface on FW is 192.168.0.1 which doesn't have a translation.
A public dns server is used to translate vpn.cust.com for the guest user.
So what I want is for the dns request of a guest user which would recieve 4.4.4.4 as a translation of vpn.cust.com to be rewritten with 192.168.0.1.
I've read a few docs about this and my problem always boils down to the fact that I'm not allowed to do a rewrite of the outside interface (4.4.4.4), it conflicts with something. So am I screwed or can this be acomplished in any other way?
Thanks in advance for any question and suggestion.
Br
//Peter
